    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
Directional Head/Fog Lights on Austin Healey?
swike
Has anyone on the forum ever heard of an Austin Healey that had directional headlights or fog lights that would turn with the front wheels? I'm getting old and it's been close to 40 years, but I think I saw them on an Austin Healey that a friend was rebuilding/restoring in the late 1960s. Am I just imagining these lights, or is it possible I really saw them?
Thanks,
/ubbthreads/images/graemlins/confused.gif
Keoke
Not to my knowledge Swike,Several cars of that era did have directional lamps but I do not think a Stock Healey was ever fitted with them. There was the practice of mounting a single driving/flood lamp on the Healey cars and that may have given you the impression that it was directional.---Fwiw---Keoke
R Directional Signal Failure Austin Healey 12
LAW75 BJ8 Directional Indicators Austin Healey 4
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
TRMark T-Series Directional Control Relay DB10 MG 4
F TR2/3/3A Horn/Directional Assembly Triumph 2
steveg Wanted - easy install tool or technique for directional/stop light lenses Austin Healey 9
rjc157 Directional Austin Healey 10
AUSMHLY BJ8 left front directional problem Austin Healey 17
T directional signals Triumph 6
jdubois TR2/3/3A TR3A directional indicator dash light Triumph 4
AUSMHLY How to make your directional flasher AUDIBLE Austin Healey 22
A eBay Stop and Directional Light Conversion Kit Austin Healey 10
K TR2/3/3A Cylinder head stud height question? Triumph 4
K TR2/3/3A Memory refresh: non ARP cylinder head studs..... Triumph 2
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
K TR2/3/3A Skimming the cylinder head. How do I find the....... Triumph 4
K TR2/3/3A cylinder head washer Triumph 0
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 10
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
K TR2/3/3A The steel head stud washers? Triumph 7
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
S Spitfire Cyl head coolant hose fitting Triumph 1
B TR6 Milling the head Triumph 5
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 30
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
tahoe healey "Convertible" vs "Drop Head Coupe" Austin Healey 8
K TR2/3/3A head gasket repair wire Randall Triumph 1
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
F TR2/3/3A head light buckets Triumph 3
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
R Big Healey 100 Head Austin Healey 4
R For Sale 100 engine block w/head Austin Healey Classifieds 3
B Surprise screw head Restoration & Tools 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
B Head Re-Torque Austin Healey 8
