Crankshaft Bearing
MKIII_Joey
Hello,
I have a question. Is it possible to drive my 3000 Healey without the brass bushing on the crankshaft for the gear shaft? Have forgotten to reasembly the bush in the crankshaft endbearing.
Thank you in advance.
WHT
Hi Joey,
I assume you mean the pilot bushing?
Unfortunately, you need the pilot bushing and you should install it since they provide support for the input shaft and keep it centered. You will have increased noise and vibration running without it and will eventually damage the gearbox.
Sorry, I understand the wish to not pull the transmission again (from experience).
Regards, Bill
EDIT: It can seem a frightening, but you should be fine. People on the forum will provide any information and/or support you need.
It is best to use a simple and inexpensive tool to press the bushing into place rather than drive it. I have an expensive one. But, you can find one for pushing bushings for $20.
If you do drive it into place, make sure you still have the recommended ID/clearances before installing the gearbox since driving the bushing can slightly close its ID.
I modified the propeller shaft tunnel slightly (added an end-cover/door) so it is much easier to install the transmission (something AH should have done). Most purists would never consider this, but the modification (i) can not be seen and (ii) makes it easy to lift the tail-shaft of the gearbox up and down when its pulled back during removal and installation (this greatly reduces required twisting and alignment gyrations).
There are lots of pictures posted online showing gearbox removal and installation. And, if you look closely, you can see many beat-up propeller shaft tunnels and tail-shafts. The tunnel modification also makes it easier to service the universal joint and hand brake; and seals well without the chance of any fumes entering the car.
Picture 2 shows the propeller shaft cover during fitting, and the red outline shows the actual size of the cutout in the stock tunnel. The silver "door" is a section from a Kilmartin propeller shaft tunnel that fits the original tunnel contours perfectly with good overlap for sealing. After painting, the modification looks "factory".
The third picture shows the modified propeller shaft insulated in preparation for installing a new interior. The only evidence that the tunnel has been modified is the insulation seams required so the cover can be removed when needed.
Healey Nut
That’s a very nice engine bay so ask yourself this re your pilot bushing/gearbox removal issue: Would you consider removing 3/4 of the oil from your engine and 1/2 the coolant from the radiator and driving the car at 70 mph for two hours down a highway?
I think your question is answered; you’re pulling the gearbox again.
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
T crankshaft (rear) bearing leak Spridgets 2
KVH General Tech Crankshaft Main Bearing and Oversize Puzzle Triumph 5
mctriumph TR4/4A Busted crankshaft Triumph 20
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
B TR6 Crankshaft long seal surface Triumph 5
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
B General MG Crankshaft Nut Removal MG 4
W Crankshaft Oil Seal Austin Healey 3
Popeye TR4/4A Crankshaft pulley recommendations: One piece alloy, two-piece steel, wide, narrow...? Triumph 12
B MGB Mgb crankshaft end play shims MG 2
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
T Wanted Wanted - 1956 TR3 Crankshaft Triumph Classifieds 0
R Wanted 3 main crankshaft MG Classifieds 0
glemon TR2/3/3A Crankshaft Question Triumph 3
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
AUSMHLY Crankshaft Starter Nut Austin Healey 10
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
P TR2/3/3A Crankshaft Thrust Washers Triumph 4
M TR2/3/3A Crankshaft Pulley Configurations Triumph 3
M TR2/3/3A Crankshaft Oil Galley Plugs Triumph 7
S TR4/4A Fair price for a crankshaft? Triumph 2
charleyf TR2/3/3A crankshaft hardening Triumph 2
Gerard Wanted: 1275 Crankshaft Spridgets 3
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
G Crankshaft Rotational Freeplay - What's going on with this engine? Austin Healey 12
O Wanted TR 3 Crankshaft please... Triumph Classifieds 1
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
GTP1960 TR2/3/3A Moss Crankshaft pulley failure Triumph 23
C Tough Bolt on front of Crankshaft Spridgets 16
TRMark TR4/4A Prepping Crankshaft Triumph 4
D TR2/3/3A crankshaft shims to align timing sprovkets Triumph 4
tinman58 TR5/TR250 Front crankshaft seal Triumph 0
2billydavies TR2/3/3A removing con rod from crankshaft Triumph 4
J TR2/3/3A Crankshaft thrust washers. Triumph 2
C Crankshaft pulley / damper Austin Healey 5
HJR TR2/3/3A Crankshaft crank bolt head[108498] Triumph 10
M For 1974 MG Midget - Crankshaft pulley bolt is 1 5/16"? Spridgets 4
M Spitfire need a crankshaft pulley for 1978 Spitfire Triumph 0
M_Pied_Lourd TR2/3/3A TR3A Crankshaft Question Triumph 3
B crankshaft/cam timing Austin Healey 10
RedTR3 TR2/3/3A TR3 Crankshaft Options Triumph 10
Gerard 1098 10CC crankshaft Spridgets 14
vette Timing Cover crankshaft pulley seal Austin Healey 6
AHS TR2/3/3A Which way does the TR3 front crankshaft oil seal face? Triumph 8
M Healey Crankshaft Thrust Washer Thickness Austin Healey 3
