TR6 Carb plug TR6
Wike
I suspect that the float plug located in the bottom of my SU175 carbs is the cause of leaking fuel. I have received new plugs and 'O' rings...question-do the carbs need to be removed in order to replace plugs?
Not if you are careful. I'd disconnect the fuel line, cap or plug it and run the engine until it stops. There should be very littl gas left in the float chamber.
Then, if you work your way around the plug with thumbnails for instance, prying and rotating until these Plastic claws are inside the opening; then you can pull straight down and out. There will be a bit of gas, but not the whole chamber full.
I cut the old O-ring and lube the new with anything slipery to avoid stressing the plastic claws
I've had plugs with one claw broken off seal just fine with a new O-ring so don't fret if that happens
Thanks for the tip. I had ordered and received new plugs and 'O' rings that I will use...once I find the time. Was issued a speeding ticket today driving my Tundra....37 in a 30, can you believe that! First speeding ticket ever.
K TR2/3/3A A TR3 plug check left to right 1234...do I lean out front carb a couple of flats?...turn down correct? Triumph 3
A carb plug replacement Triumph 3
K TR2/3/3A The carb linkage "bell crank". Triumph 9
Govtslug TR6 Carb Problem Triumph 8
W 2024 HD8 Carb Rebuild Austin Healey 4
J Spitfire Carb Conundrum Triumph 3
J Spitfire SU Carb Jet Assembly Seized Triumph 1
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
S Carb Float Levers Austin Healey 9
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A Another Carb question. Triumph 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
jlaird MGB V6 carb help MG 14
9 For Sale: Thermocarb - complete setup including special manifold Austin Healey Classifieds 1
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
E MGB SU CARB OIL 1965 mgb MG 3
Michael Oritt SU H6 carb for Le Mans--order of assembly of fuel bowl lid Austin Healey 2
D Tri carb: order of installation question. Austin Healey 5
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
E MGB SU carb air cleaners MG 10
Healey Nut Tri-Carb Project Austin Healey 217
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
tahoe healey Dumb carb question Austin Healey 23
