Carb Oil ???
George Zeck
I'm a little slow today and was wondering what kind of oil I should add to the carbs ? I've heard anywhere from 10/30 to household oil to tranny fluid.
Any and all advice would be welcome !
Tx-
Geo Zeck
/ubbthreads/images/graemlins/hammer.gif
Marvel mystery works pretty good.
Mark
George, the original dashpot oil is nothing more than 20W. Marvel, tranny fluid, or straight 20W are all things I've used successfully.
Jeff
George, you can use most any weight oil in the carb dashpots.
The heavier the oil the more resistance to the air piston moving so when you hit the gas the mixture will get richer momentarily until the air piston rises allowing more air flow. This gives a similar result to the more conventional accelerator pump found on N.American cars.
I always use what I have in the engine (20/50), as I usually have a quart of it handy in the car.
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
E MGB SU CARB OIL 1965 mgb MG 3
AUSMHLY Oil in rear carb Austin Healey 33
RAC68 Carb Oil Cap Loosens Austin Healey 5
T Oil leaks under carb are - tappet inspection plate Spridgets 6
T Breather Tube - Oil dumping in air filter and carb Austin Healey 30
SkinnedKnuckles Question about AH 3000 carb damper oil Austin Healey 21
58Custom How often should carb damper oil need topping up? Spridgets 4
tahoe healey Carb damper oil Austin Healey 6
T Carb Dashpot Oil Level Spridgets 6
George Zeck Carb Oil & Stalling Issues .... Spridgets 4
A Oil leaking from ZS carb Triumph 5
tahoe healey Oil in the back carb Austin Healey 6
G Carb oil leaks out MG 8
K TR2/3/3A The carb linkage "bell crank". Triumph 9
Govtslug TR6 Carb Problem Triumph 8
W 2024 HD8 Carb Rebuild Austin Healey 4
K TR2/3/3A A TR3 plug check left to right 1234...do I lean out front carb a couple of flats?...turn down correct? Triumph 3
J Spitfire Carb Conundrum Triumph 3
J Spitfire SU Carb Jet Assembly Seized Triumph 1
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
S Carb Float Levers Austin Healey 9
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A Another Carb question. Triumph 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
