BJ8 Exhaust Hanger Pictures Wanted
fwtexasbj8
I just got my car running after a total engine rebuild and it is running great! No more ticking sound! Root cause was broken rings in 4 of 6 cylinders.
Unfortunately, on the way home from the Texas Healey Roundup this past weekend, I was rear-ended about a mile from home. Lady that hit me said she had been following me for several blocks and was "admiring my car" then failed to stop in time and tagged me in the right rear at a red light. I think I was very lucky in no damage to the rear shroud or fenders but it did buckle my boot lid a bit. Should be an easy fix, I think. The only mechanical damage I have found so far is it broke the exhaust hanger on the aft passenger side.
Looking at the parts catalogs, it is apparent I never had the correct exhaust hanger arrangement so would like to put it back right now. Does anyone have a good set of pictures of the driver and passenger side mounts at the rear of the car where the mufflers cross over?
Patrick67BJ8
Was your car in the car show?
Patrick67BJ8
Was your car in the carvshow
Yes Patrick, it was the black one parked outside.
is your exhaust a stock system?
F
fwtexasbj8
Kind of. It is a chrome Tourist Trophy system from Moss
Patrick67BJ8
Mine is a Bell system, but I believe all of the parts duplicate the originals. Hanging Kits should be available from the usual sources.
Is this the area you are wanting? Located next to the left rear tire.
F
fwtexasbj8
Patrick,
Thanks for these and they help. Do you have any pictures of the mount on the other side behind the right rear tire?
Patrick67BJ8
Resonaters hanging hardware.
E BJ8 Seats, Exhaust Hanger, Heat Shield Locations in Floor Austin Healey 7
AUSMHLY Gasket, Inlet Manifold to Exhaust Manifold BJ8 Austin Healey 8
BJ8Healeys BJ7/BJ8 Exhaust Systems Austin Healey 24
crispy How to Remove the Exhaust Manifold?? [late BJ8] Austin Healey 27
BN6 BJ8 Outrigger Cut Out For Exhaust Austin Healey 3
S Side exhaust system for BJ8 Austin Healey 16
H Tourist Trophy Exhaust on Healey Bj8 Austin Healey 2
H BJ8 Exhaust System and Brake Servo Austin Healey 16
J BJ8 Ph I Exhaust System Austin Healey 3
Jeepster BJ8 exhaust down pipe gaskets Austin Healey 6
M ANSA exhaust for a BJ8 Austin Healey 1
C BJ8 Stainless Steel Exhaust - throaty sound ? Austin Healey 4
Jeepster BJ8 exhaust mounting points Austin Healey 17
ttrotter 67 BJ8 Exhaust exit ? Austin Healey 4
D Installing BJ7 version exhaust system on my BJ8 Austin Healey 3
J Side Exit 1960's Style Exhaust on my BJ8 Austin Healey 23
Xte How to fix my new BJ8 SS exhaust system ? Austin Healey 5
wangdango BJ8 exhaust? Austin Healey 6
N Convert BJ8 exhaust to single silencer Austin Healey 6
G exhaust manifold for my BJ8 Austin Healey 4
N Erratic exhaust on BJ8 Austin Healey 17
Schroeders BJ7 Exhaust on a BJ8: do I need downpipes? Austin Healey 10
nicko replacing exhaust bj8 Austin Healey 16
Schroeders BJ8 Stainless Exhaust Q's.. Austin Healey 18
Marvin Gruber Austin Healy BJ8 exhaust brackets Austin Healey 2
bighealeysource BJ8 exhaust question Austin Healey 6
S BJ8 Stainless Steel Exhaust Austin Healey 7
David_K BJ8 stock exhaust Austin Healey 2
Wana Anyone replacing their BJ8 exhaust?? Austin Healey 2
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
