How to fix my new BJ8 SS exhaust system ?
Xte
Hello,
I've tried to fit my new stainless steel exhaust system in my BJ8 phase 2 with the complete AH spares fastening. But I'm not sure how to fix the fasteners and where to drill the holes in my new floors ...? Could someone help me by sending pictures of the original BJ8 exhaust system fixations ... It will help me so much ...
I guess to mount my exhaust tomorrow.
Thank you in advance for your help ...
Patrick67BJ8
Xte said:
Hello,
Send me your PM to my message ctr and I'll send you pics of what I have. I made a similar request for the same thing you're asking for and I guess it's either TOP SECRET or nobody really knows and/or once a person goes through great pain finding the info, they must figure you should do the same. I asked for the front places to attach the front mounts and a vendor sent me a template for the rear resonator mounts. I have pics of mounting locations on an original car, but no measurements as of yet but I'll be happy to share. Measurements to be acquired at a later date, CAD drawing made and planning to retire after selling drawings.
I'd help if I could, but this is a tough one. If you've fitted new floor boards I would expect captive nuts, or at least holes, for the hangers to be already fitted/drilled. I put a new boot pan in and the holes were drilled for the hanger hardware but I had to weld in 'studs' made from ground down bolts and doublers. Not sure the holes are in the right place anyway; had to reposition the ears on my improvised resonators.
This is a terribly complex setup, there's a hanger with a 'T' up front just behind the cutout in the outrigger, two hangers diagonal to each other towards the rear of the floorboard, another hanger just before the 90-deg bend that's bolted to one of the chassis angle braces, and the two aforementioned holes with studs in the floor pan.
Plus, you need a boat load of hardware (usually comes as a kit). Think Rube Goldberg designed this system.
Patrick67BJ8
I sent him a lot of photos to help, but there's no measurements. I have access to an unmolested 67 BJ8 that I took about 35 pics of this area in hopes of helping me get everything lined up and the holes drilled in the correct place the first time around. I hope to go back to the same car and get detailed measurements and then do a CAD of them and make them available to whoever needs them. It may be a month or two away before I get to it.
Xte
Xte
Thanks Patrick, for your pictures and your help.... :thumbsup:
It helped me having an idea of the global area where to Locate the fixations, after adjusting the complete Exhaust, I made a reverse engineering and drill all the holes threw the floors panels ....
It was hard work, 2 people and 8 hours of working .... Ouahhh I expect to need less than 3 hours !
Thank you again for your help ....!.! :yesnod:
bighealeysource
Bronze
Like everything I end up doing on my Healey - think it will take "x" hours and ends up taking two or three times longer !!!!
S BJ8 tachometer fix Austin Healey 2
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tr6nitjulius General TR DYI don't park on bare concrete fix Triumph 1
HealeyPassion Hood scope chrome gap fix ... Austin Healey 0
T TR6 Carb. Float Chamber Fix Triumph 5
A TR2/3/3A how do i fix this hood line? Triumph 5
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
UmmYeahOk GT6 What do I need for a speedometer fix? Triumph 16
warwick-steve Final fix for clutch pipe to master cylinder leak?? Austin Healey 13
W radiator spigot fix Austin Healey 11
Geo Hahn Off Topic Photobucket Fix Triumph 17
K TR2/3/3A Rebuilt steering has creative fix for NA worm bearing! Triumph 4
Scotsman TR4/4A How to fix sagging rear end. Triumph 8
M_Pied_Lourd TR2/3/3A The Newest Bug to Fix...Now with Video! Triumph 43
M_Pied_Lourd TR2/3/3A The Newest Bug to Fix... Triumph 15
Got_All_4 TR2/3/3A Has anyone tried to rewind/fix a fuel tank sending unit? Triumph 11
Joe Reed MGB Another easy fix....upper radiator bracket MG 5
P MGB Vinyl window scratch/haze fix ? MG 3
S TR2/3/3A green fiberglass fix it stuff Triumph 9
Jim_Gruber Need advice on how to fix this one. Spridgets 7
Elva164 Help me fix the Cortina! Lotus 9
W Emergency rotor fix Austin Healey 2
mailbox General Tech Fix, replace or rewire? Triumph 8
J Finally a fix for the SU pump Austin Healey 5
dcoplan I've got a twisted camshaft-to-oil pump pin. How to fix?? Spridgets 1
DanLewis Would a Panhard bar fix this problem? Spridgets 11
Mink TR4/4A Help me fix my reverse lockout... Triumph 3
bthompson A quick 1500 fix for when you go for reverse and rip off your shift lever! Spridgets 4
R Smitty Speedometer Cable Fix Austin Healey 1
angelfj1 TR2/3/3A HELP! Need quick fix for missing bonnet hinge pin. Triumph 5
bighealeysource Anyway to fix very slight dent in body without painting ? Restoration & Tools 7
J TR6 looking forgood shop to fix my tr6 Triumph 2
X don't fix it if it ain't broke Spridgets 1
R Fix The Austin 1800 Other British Cars 10
K Clutch fork fix Re: the 1/4" bolt repair. Triumph 10
H sloppy shock arm fix Austin Healey 4
S How to fix Vapor locking from happening Triumph 42
tinman58 TR2/3/3A Tr3 trans fix Triumph 3
regularman What is the permanent fix for rear wheel seals Spridgets 14
regularman I found the fix for the stromberg on the 1500 Spridgets 6
bighealeysource ideas on how to fix dents on frame Austin Healey 15
L Simple fix for leaky tappet cover Austin Healey 0
A Steering Wheel Fix Austin Healey 5
K Brake pedal doesn’t move mcylinder didn't fix Triumph 7
M Weeping fuel pump fix Triumph 41
doughairfield how would you fix this? Triumph 9
M Car goes "click" when trying to start - the fix Spridgets 8
