Lots of leftover parts from BJ8 and BT7 Tri Carb restorations .
PM me for costs and shipping info . I can take most items to Ogdensberg UPS store to reduce shipping costs .
I CANT DO THIS UNTIL THE BORDER OPENS AGAIN !!!!!!!!!!!!!
Make me sensible offers on all items I'm not looking for huge $$$ just want help enthusiasts keep them on the road , I also have some stuff not listed . Just ask I may have what you need .
Let keep these old girls on the road .
2- original starters
1- adjustable hub steering wheel , needs restoration for cracks etc .
1-original NOT REPAIRED generator mounting plate off the side of the engine .
1- BT7 clutch pressure plate
1-rear engine plate
2- full sets original pistons standard size very useable condition .
1- set original Con Rods
4- Bumpers , 3 original , 1 repro .originals for rechrome repro driver quality.
2-BJ8 fuel filler necks and caps
1- 4 blade alloy fan rare part
2- oil filter assemblies with 90 degree adaptor piece
3-oil pumps
1-pair Girling brake servo brackets
4-original air filters BJ8 2 pairs
1-set 2 wing knock offs , coarse thread
1-stub axle right side /hub extension , good splines coarse thread .
1-pair chrome corner pieces originals good rechrome candidates
1- pair wing flashes originals
4-chrome BJ8 door waist moldings originals , good rechrome candidates
1-BT7 flywheel with starter ring
1-BT7 Harmonic balancer ,for core or rebuild .
1-pair BJ8 foam door caps
1-distributor drive gear
1-oil pump drive gear
1-BT7 crankshaft for regrind
1-timing cover
1-original spare wire wheel original paint in good condition with bias ply tire ,perfect for concourse
1- set driver quality knock offs two ear type coarse thread .
3- sets original valve cover cap nuts
1-set timing gears useable
8-brand new left and right moulded end cap rubbers for soft top surround seals
1pair new radius arm bushings
1- original fuel pump with BT7 mount plate (non electronic) in good rebuildable condition
1- original panhard rod for BT7 , sandblasted primed and painted plus new bushings and bracket etc .
misc internal engine parts , main caps , timing chain adjusters etc .
other ods n ends not listed …..just ask me I may have what you need .
