For Sale BJ8 and BT7 parts for sale
Healey Nut
Healey Nut
Pretty sure I do , I have 3 or 4 old bumpers , I think one of the rears is a repro and one is an original .
I will send some pics if you have a direct email address .
The issue you will face is with the border between the US and CAN still shut down shipping direct from CAN will be stupid expensive .
Healey Nut
Healey Nut
I have three , the shiny one is repro the others are original.
BLong63AH
Member
Sorry I never got a notification on both your replies. I will PM you both about the bumpers. Have me a little nervous about shipping form Canada.
Thanks Again
JDMTX
Do you have any door hinges or hood hinges? I am needing a door hinge for the right side and a left hinge for the hood.
Thanks,
Healey Nut
Healey Nut
Door hinges probably, hood hinges no .
Do you need an upper or lower hinge , they are different .
I will take a rummage in the parts bins and see what I can find and take pics .
Healey Nut
Healey Nut
This is the only door hinge I have , looks like an upper BJ7 BJ8 Hinge it’s useable .
let me know and I can sandblast it for you .
JDMTX
Thanks for the feedback. I need an upper hinge for right side door. I've got a 1960 BT7. Are they interchangeable between models?
Healey Nut
Healey Nut
No the doors on a BT are very different from a BJ
Healey Nut
Healey Nut
Yes I do I have a good useable repro that came off my sold 64BJ8 and also an original off my 62 which will need rechrome .
cant send pics right now as I won’t be home till later next week .
check the post a bit further back in the thread there’s a pic there .
Healey Nut
Healey Nut
Healey Nut
Healey Nut
Healey Nut
Healey Nut
ken lippett
Lots of leftover parts from BJ8 and BT7 Tri Carb restorations .
PM me for costs and shipping info . I can take most items to Ogdensberg UPS store to reduce shipping costs .
I CANT DO THIS UNTIL THE BORDER OPENS AGAIN !!!!!!!!!!!!!
Make me sensible offers on all items I'm not looking for huge $$$ just want help enthusiasts keep them on the road , I also have some stuff not listed . Just ask I may have what you need .
Let keep these old girls on the road .
2- original starters
1- adjustable hub steering wheel , needs restoration for cracks etc .
1-original NOT REPAIRED generator mounting plate off the side of the engine .
1- BT7 clutch pressure plate
1-rear engine plate
2- full sets original pistons standard size very useable condition .
1- set original Con Rods
4- Bumpers , 3 original , 1 repro .originals for rechrome repro driver quality.
2-BJ8 fuel filler necks and caps
1- 4 blade alloy fan rare part
2- oil filter assemblies with 90 degree adaptor piece
3-oil pumps
1-pair Girling brake servo brackets
4-original air filters BJ8 2 pairs
1-set 2 wing knock offs , coarse thread
1-stub axle right side /hub extension , good splines coarse thread .
1-pair chrome corner pieces originals good rechrome candidates
1- pair wing flashes originals
4-chrome BJ8 door waist moldings originals , good rechrome candidates
1-BT7 flywheel with starter ring
1-BT7 Harmonic balancer ,for core or rebuild .
1-pair BJ8 foam door caps
1-distributor drive gear
1-oil pump drive gear
1-BT7 crankshaft for regrind
1-timing cover
1-original spare wire wheel original paint in good condition with bias ply tire ,perfect for concourse
1- set driver quality knock offs two ear type coarse thread .
3- sets original valve cover cap nuts
1-set timing gears useable
8-brand new left and right moulded end cap rubbers for soft top surround seals
1pair new radius arm bushings
1- original fuel pump with BT7 mount plate (non electronic) in good rebuildable condition
1- original panhard rod for BT7 , sandblasted primed and painted plus new bushings and bracket etc .
misc internal engine parts , main caps , timing chain adjusters etc .
other ods n ends not listed …..just ask me I may have what you need .
ken lippett
1-rear engine plate
3-oil pumps
1-timing cover
are the knock offs available ?
condition ?
will they fit a BJ8?
Healey Nut
Healey Nut
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
BJ8Healeys Bt7 ---> bj8? Austin Healey 15
D Differences between BT7 and BJ8 engines. Austin Healey 12
6 Dash Instrument Conversion: BJ8 > BT7 Austin Healey 3
6 BJ8-BT7 Tri-carb Conversion? Austin Healey 7
J BJ8 versus BT7 Shroud Austin Healey 11
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
