Anybody ever rebuild a lever arm shock?
PAUL161
Peter rebuilt a pair for me 10/12 years ago for our MGB and there still in perfect condition. He rebuilt my 55TF shocks about 8/9 years ago and they are also in perfect condition! They also look like new when you get them back. (y) :driving: I should have said (Better) than new!
vping
vping
Bronze
Post from the post. Don't even have that TD anymore. I do have another which I have to finish up, either before or after the T.
DutchConnection
Just curious to know what it takes to rebuild any of the lever arm shocks that are on our cars.
In spite of the horror stories, it depends on what you're after? I imagine maybe only a refill/refresher with hydraulic oil (and if needed replacements of gaskets)? If that is the case, easypeazy. Youtube is your friend and then your workbench and some spanners, order the right fluid (basically the same as put in motorbike forks, fork oil) order the correct type (cork) gasket replacement sets and get on with it. I did 4 onnmy Healey Sprite in 2 hours (the first took 1 hour careful stepbystep tryout, the other 3 now routinely).
Consider reading up on the viscosity rating of the suitable hydraulic fluid. You can refill the front lever arms with one grade higher stiffness than recommended for good steering control and the rear with the recommended stiffness fluid for comfort.
Randy Forbes Healarossa; anybody ever seen, or heard of it? Austin Healey 2
M TR2/3/3A Anybody ever dye wool carpet? TR3 Triumph 0
A Anybody ever order anything from Paeco Industries Austin Healey 4
D Anybody ever hear of...... Jaguar 1
jdubois Anybody ever receive a BMIHT cert that was wrong? Triumph 13
YankeeTR Anybody ever used Krown rust proofing? Triumph 0
regularman Has anybody ever put a square sprite front end on Spridgets 11
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
Csarneson Anybody feeling optimistic? Or drunk? Austin Healey 21
Keoke Anybody heard: Austin Healey 9
Got_All_4 General TR Anybody Hear or Use This Hot Spark System? Triumph 10
Csarneson Anybody seen this Front Shock Conversion Kit before? Austin Healey 6
Gerard Anybody have...? Spridgets 9
TRMark General Tech Anybody Using Star Tron Triumph 2
J Anybody driving a 2018 Jaguar XJ? Jaguar 3
J anybody tell me why this thread closed? Austin Healey 4
TR3TR6 TR2/3/3A Anybody else having a bad day! Triumph 31
M TR2/3/3A Does anybody use the oils and lubes from the moss motors site? Triumph 3
TomMull Post-War Other Anybody interested in 10s? Triumph 15
2billydavies TR2/3/3A anybody need a spare rear bumper? Triumph 8
catfood Rivnuts anybody Austin Healey 19
H Joan Baex 1961 flat floor--silver exterior--anybody know what IRS sold it for? Jaguar 0
H TR4/4A Triumph 250-K by Pete Brock--anybody recall how much Brock advertised it for? Triumph 1
K Anybody Try Exactline blades? Restoration & Tools 4
B TR2/3/3A Anybody finish their car in laquer? Triumph 18
64Elan Anybody interested in an Italian Spridgit? Spridgets 3
Gerard Is anybody able to ID these racing/sports seats? Spridgets 0
Gerard Anybody have a steering wheel emblem for '68 Sprite stock steering wheel? Spridgets 11
S Anybody tried this Alternator ? Austin Healey 11
W Anybody have one of these surplus? Spridgets 5
krswen TR2/3/3A Anybody own TR3 TS 59719 L? Triumph 0
krswen Anybody own Series 1 E-type coupe 1E 32257? Jaguar 2
TR4nut TR6 TR6 under dash pics? Anybody? Triumph 9
DNK Wedge Anybody have any "good" adhesive? Triumph 2
B anybody know how and where I can get the cable ends for the heater cable? Spridgets 13
AN5Sprite Anybody Have A Bugeye Fuel Gauge Core To Spare? Spridgets 3
J Anybody need a 1500 motor? Spridgets 2
R July 15 Fairfield Ohio meet anybody going? Spridgets 8
Gerard Does anybody have a busted crank? Spridgets 3
regularman Anybody in Arkansas? Spridgets 2
rkep01 Anybody have one of these available? Spridgets 7
regularman Anybody got any cheap used distributor parts Spridgets 8
T TR2/3/3A Anybody need a TR3 frame and suspension Triumph 5
T Anybody Want to Play "Identify the Crud"? Triumph 2
DNK Anybody? Triumph 3
Banjo TR4/4A AAAAUG! anybody got an extra TR4A piston? Triumph 3
DNK Anybody have .. Lotus 1
jdubois Anybody tried these floats? Triumph 7
DNK Anybody need an Eclat Lotus 4
longbridgehealey Does anybody know this car?? Spridgets 0
