HealeyPassion
I got my front shroud back yesterday with the carb. access panel fabricated. Chris Mack, once again, did an absolutely beautiful job …. perfect 1/8" gap leaves room for paint thickness on both surfaces. The access panel is located in place with 2 stainless steel pins... then two screws hold it down. When the hood is in place, the 2 screws can't come out when driving so it's effectively secured. Since the access panel has compound curves, fabricating a quality carb access panel is a bit more complex that you might think. The metal work on the front shroud is complete... Works style front oil cooler ducts and carb. access panel. Now moving on to Works style side vents (years ago I got a rubbing from Pat Moss's car to get exactly the right size/shape).
Steve
Steve
