1500 mg midget, weber dgv carb & affect on timing
recordsj
What do people know about a 1500 mg midget that has a weber dgv carb on it on how it affects where you set the ignition timing. I was told by one person that with a weber carb, it likes to have the distributer rotated to advance the timing by 10 deg or so for the engine to work well. So in other words if the stock ignition timing is supposed to be 10deg BTDC, then set the ignition timing to around 20deg BTDC.
Can anybody confirm this and/or provide any insight here?
Fail to understand how the carb setup can have any effect on the timeing.
I vote no direct relationship.
Hers what the problem is Im sure. The Weber DGV is a very complex carb. (In comparison to an SU) It has pin holes inside the throat that are mostly completely covered when the throttle plates are at an idle. These holes control your vacum advance. Mainy weber carbs that are not jetted correctly will have owners overcompensating for an idle by means of teh adjustment screw. By uncovering more of the pin hole you increase the vacum.. I have seen alot of these conversions where they adjust the timing so the vacum advance seems to work correctly all because they were improperly jetted or had worn throttle plates. To understand that carb go to pierce website and dowload all the tuning instructions. Then when you get it reight, be prepared to start all over next year.
If you start at 20BTC you are going to be way ahead by the time your mechanical advance finishes up. It really depends on what type of distributor you have but that could be way too much advance. Like some have said...the weber will have ported vacuum for the vacuum advance. Some distributors are set up for manifold vacuum for the advance and some are set up for ported vacuum. I think it makes the advance curve a bit different. I would start by researching the distributor model number to give some idea what it will be doing to your advance. I have a spreadsheet with tons of distributor model numbers and the stock advance curves if you want.
JC
What I have is a PDF file. I can't attach it here. I think I got it from Telgerizer but if you need me to I can email it to you. Just let me know the email address.
JC
R k&n air filter p/n for weber dgv on 1500 midget? Spridgets 7
M Weber DGV Carb Conversion for 78 MG Midget 1500 MG 0
M Weber DGV Carb Conversion for 78 MG Midget 1500 Spridgets 26
R weber dgv 32/36 installation on 1500 midget? Spridgets 4
J Weber on 1500 Mg Midget Spridgets 2
Y Weber carb conversion, Midget 1500 Spridgets 21
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 7
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
DanLewis 1500 cc MG Midget Radiator in a Bugeye??? Spridgets 5
J 1500 mg midget fuel issue Spridgets 2
J 1500 midget master cylinder Spridgets 10
T ZS Question for 76 1500 midget Spridgets 33
T 76 midget 1500 oil pressure lines? Spridgets 15
frankenstang57 Educate me on the Midget 1500 MG 4
R Overdrive/5 speed options for 1500 Midget? Spridgets 21
P how to replace rear main seal in 1500 midget Spridgets 2
R pcv valve for 1500 midget? Spridgets 18
R spark plug for a 9:1 ratio 1500 midget? Spridgets 5
T 76 midget 1500 engine crud Spridgets 4
RickB Seat recovering, 1500 Midget Spridgets 18
R 1500 midget clutch inspection? Spridgets 3
R oil feed kit for 1500 midget? negatives in this? Spridgets 5
Rhodyspit75 Spitfire Midget carbs and manifold on 1500 Spit Triumph 6
D Vacuum unit for 1500 Midget Spridgets 7
P holes in 76 midget 1500 front bumper Spridgets 6
R compression test procedure on 1500 midget Spridgets 5
G 79 midget 1500 clutch? Spridgets 5
A MIDGET 76 1500 CLUTCH SLAVE CYLINDER Spridgets 1
bcbug Midget 1500 Hose Connections Spridgets 9
RickB Midget 1500 dual circuit Master Cylinder troubles Spridgets 7
7 79 midget 1500 Emission Removal Spridgets 3
G 79 mg midget 1500 wiring Spridgets 7
bcbug 1500 midget carb replacement Spridgets 38
A 1300 cam bearings in Midget 1500 Spridgets 3
M 78 1500 Midget Tire Sizes Spridgets 1
