TR2/3/3A Copper pipe from pump to carbs
karls59tr
Bronze
I want to replace the non stock pipe the PO installed. What is the correct size 3/16...1/2". Is the pipe just copper or copper nickel or something else?
Frank_D
Try Moss part 371-960, Karl. Depending on your vacuum unit you have other options to suit you application. Look under Ignition/distributor.
K
karls59tr
Bronze
Not the vacuum line but the fuel line as in 376 220. I want to buy the copper pipe locally rather than the Moss part since I do not need the stock fittings since I am running an electric fuel pump.
CJD
Copper is not recommended, as it will eventually crack from vibration. The original fuel line is steel. NAPA and other suppliers sell easily bent steel tube that you can use to fabricate the lines. You will,, of course, need fittings and a flare tool.
K
karls59tr
Bronze
Would that be 3/8" steel tubing?
Hamish Racing
Karl
May be consider just running fuel tube round the back of the engine along the square box section in front of the battery.
it’s more direct and cooler.
in my pic it’s via an elec pump on the left but worked just the same with the mechanical pump.(highlighted in yellow) Just need to swap over the carb float bowl lids.
But I realise it’s not a modification for everyone.
K
karls59tr
Bronze
Karl
Good idea. How is it fastened to the frame there in front of the battery?
Nobbster77
I have used copper tube fuel line since 92 with no cracks, the rubber connection and the bends dampend down any vibration which will prevent work hardening and fatigue but even using steel pipework its always worth checking the pipes reguarly for cracks
Charleyf has the pipe dimensions spot on
Steve
NutmegCT T-Series the copper pipe? MG 19
M brake pipe copper straps Spridgets 19
C copper brake pipe lengths Other Cars 12
C copper brake pipe lengths Austin Healey 2
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
TomMull Copper nickel lines again Restoration & Tools 0
J TR2/3/3A Figure of Eight Gasket Compression - Copper vs. Steel Triumph 18
glemon General Tech Nickel Copper Brake Lines Triumph 10
jfarris TR2/3/3A Which spark lug to use - copper/platinum/iridium Triumph 14
CJD TR2/3/3A Steel vs Copper fig of 8's Triumph 20
K TR2/3/3A Copper fuel line..... Triumph 6
S TR2/3/3A copper gasket sealer and push rods Triumph 10
Jim_Stevens TR2/3/3A A-type OD operating valve copper washer Triumph 3
S Will copper grease work for squeeling brakes? Austin Healey 3
tinman58 TR6 Copper washer? Triumph 5
DNK Copper in Brake Fluid Other Cars 2
Rut Copper rivets Spridgets 9
Patrick67BJ8 Copper Drain Lines for BJ8 Carb/Intake Manifold Austin Healey 30
dklawson Copper Composite Head Gaskets - Sealant or No? Triumph 6
bighealeysource Overflow copper tube from carb manifold ? Austin Healey 2
The_architect oil pressure gauge lines: steel vs copper Spridgets 8
H Re-use of a Copper Headgasket Triumph 7
W Copper fuel lines Spridgets 10
Hairyone copper head gasket Spridgets 5
K Installing Head bolts and copper gasket Triumph 12
heliguy Copper or Copper Nickel Brake Pipes? Triumph 4
S TR2/3/3A TR3 Copper Head Gasket -- quick questions Triumph 8
MTribe special bolt for copper washer on sealing block? Triumph 2
6 Thor hammer restoration w/ copper heads Restoration & Tools 2
Morris Copper spray and head gasket instructions??? Spridgets 5
Steve_S Painting Copper Restoration & Tools 2
PATR8 Wedge Copper [my TR8] is out Triumph 2
davelgee copper head gaskets? Other Cars 2
healeyboz Copper Gasket Spridgets 1
B Copper gaskets for master cylinder, E-Type Jaguar 3
T head gaskets?-copper of steel? Triumph 4
R TR4/4A TR4A copper fuel line kits Victoria British Triumph 4
V Copper Brake Lines? Triumph 27
G Copper Brake Pipes for MIdget Spridgets 3
Z Copper spray and coated head gaskets? Triumph 0
D Copper core plug wires MG 3
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
R Valve Drain Pipe Austin Healey 13
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
Got_All_4 TR6 TR6 Down Pipe How They Last Triumph 6
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T Exhaust Pipe Hose Austin Healey 9
WHT Vacuum Advance Pipe Austin Healey 7
