LED Dash Light Upgrade
Rob Glasgow
This has been covered before but I would like to show you my solution. I ordered 10 LED E10 base bulbs in warm white from ebay. Took 3 weeks to arrive. Total cost $12.50 delivered. Installed 4 in the gauge lights and one in the turn indicator. The size of the bulbs fit perfectly, even the turn signal tube. You can see the results. I didn't do a 'before' photo, but if you've driven your Healey after dark, you know what that looks like. The bulbs look like good quality and the results are brilliant. You do get some leg light as a benefit..... As you know, the fuel and oil pressure/temperature gauge have a blue plastic lens around the edge which gives those gauges the tint.
Do you still have Positive ground on your Healey ?
Edit, found some on eBay that work with either polarity.
(Non Polarity, works either Positive or Negative earth)
Just ordered mine for my Tri Carb project rally car .
Hey Rob,
Fantastic!
Curious minds want to know. Why is there so much light bleed in the footwell?
"The size of the bulbs fit perfectly, even the turn signal tube."
Have you modified the E10 bulb holder/insert in the rear of the case? The stock ones keep all the light in the gauge.
I spent a bunch of time on this exercise a long time ago. I'm curious what's lighting up the footwell.
I guess if you want to light up the footwell when driving, it's a good thing :smile:
Nice job, thanks for sharing.
Roger, A majority of the light bleed comes from the bulbs installed on the gas and oil/temp gauges. On those gauges, the bulbs are held on the outside of the gauge by the retaining bracket and shine through the blue plastic len covers onto the face. I think the old style bulbs did the same thing but were so dim, you didn't notice.
The bulbs for the speedo and tach are enclosed completely in the gauge canister so no light escapes to the footwell.
The bulb is small enough to be inserted inside the tube of the direction indicator. I mentioned that because someone in an earlier post said their led bulb was too large to fit inside the tube and they had to tape in on the end.
Rob, that makes total sense. I forgot you have different oil/water and fuel gauges then the later models. Different design.
Which by the way I like the earlier gauge face design better. Said in a whisper so my BJ8 can't hear that.
Here‘s a side by side of the original and LED bulbs.
Bob, Several years ago I tried a similar single direction led bulb and all it did was light up the back of the dash. The lights on the small gauges have to emit light out the sides in order to reach the face.
Roger, how do the lights attach to the newer BJ7 and BJ8 small gauges? Do they insert in a hole in the back of the can like the big gauges?
That seems like a more elegant solution. It's more like a homestyle can light than the bare bulb approach of the earlier cars......
Bob, do you think using aluminum foil around the back of the water/oil and fuel gauge to limit the light bleed may help? If it’s safe... not sure if it would be an electrical issue. Maybe some other type of flexible material.
The 'hot' terminal is the pointed one at the base of the bulb; everything else is either isolated or grounded, so no issue with safety. I have 'lighted footwell' in my BN2, but don't drive it much if at all at night. Maybe use a filler like an RTV?
B Dash Light Replacement [not with LED] Austin Healey 6
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
Rob Glasgow E10 Base LED Dash Bulbs Austin Healey 17
Marla TR4/4A Led dash lights Triumph 0
P LED Dash Lights Spridgets 1
K TR2/3/3A LED dash bulbs again? Triumph 2
gbtr6 TR6 LED Dash Lights Triumph 8
PAUL161 General MG LED Dash and Instrument Bulbs POS or NEG ground. MG 8
S LED Dash Bulbs Spridgets 10
Boggsy64 MGB LED dash bulbs MG 3
hondo402000 LED Dash lights Triumph 15
PAUL161 T-Series MGT 7 inch LED Headlights MG 4
B Positive-Ground LED Light Strip Austin Healey 8
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
J LED lights for PL 700 Restoration & Tools 12
Guido36 LED Headlight Upgrade Austin Healey 1
bighealeysource LED Instrument Lights Austin Healey 12
linuxcoupe General MG Lamp to LED Conversion - How many ballasts to use MG 5
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
BoyRacer LED Turn Signals Austin Healey 5
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
P LED Brake Lights Austin Healey 2
EWD TR6 LED instrument conversion / Dimmer. Triumph 25
B TR6 LED Headlights Thouights? Triumph 28
T Decreasing Intensity of LED Lighting Austin Healey 3
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
Michael Oritt LED bulb/resistor wiring question Austin Healey 24
johnrip Wedge TR7 led light conversion question Triumph 1
ckeithjordan TR2/3/3A LED Flasher Problem Triumph 13
AUSMHLY E10 Light bulb, 2.2w vs 5w vs warm white LED Austin Healey 4
Lukens TR2/3/3A Led flasher relay? Triumph 3
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
R TR2/3/3A Positive-ground LED lights Triumph 13
Martinld123 Just installed LED headlights in BN2 Austin Healey 15
Bob_Spidell LED Headlamps Austin Healey 14
Gliderman8 TR6 Correct LED flasher relay Triumph 6
N Charging warning light LED conversion Austin Healey 29
S LED or Quartz-Iodine headlights for my '67 AH 3000 Austin Healey 22
J LED Brake / Turn Signal Austin Healey 4
Martinld123 Problem Using LED lights with Existing Brake Lamps Austin Healey 20
Joe Schlosser LED Turn signals Austin Healey 9
Joe Schlosser LED flashers Spridgets 2
Gliderman8 General TR Let there be [LED] light! Triumph 18
D LED shop lights Restoration & Tools 10
GTP1960 TR2/3/3A LED headlight question Triumph 11
gbtr6 TR6 LED light bulbs questions Triumph 20
jfarris TR2/3/3A Moss LED Tailight Kit Triumph 4
D TR2/3/3A TR3 LED Lights? Triumph 5
