MGB Zenith 175 cd carb damper oil
prc
Why is the damper oil I put in the chamber leaking out the weep in the diaphragm cover? I only put a capful in after I had the cover off. It seems like it comes out when I rev it up.
Paul
Just put in enough to feel pressure when screwing cap on, about half way down.
A common mistake is to add too much oil. Like Larry said ad only enough oil to create resistance when putting the damper back in, halfway up the cylinder is plenty. If your cylinders are full, suck some of the oil out and the problem will go away. Once added after rebuild, I haven't added oil to mine ever since. PJ
A Zenith 175 CD's Triumph 19
R Zenith Stromberg CD 175 float replacements? Triumph 3
M zenith stromberg 175 cd Triumph 24
M zenith stromberg 175 cd. Triumph 7
H Zenith Stromberg CD 175 Too rich Triumph 7
J Zenith Stromburg 175 carburator tune? Other British Cars 3
R Zenith 175 CD Choke Triumph 0
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
Celtic 77 MGB Tinny Zenith air regulator MG 0
P Zenith Carburetor Triumph 2
V MGB Zenith Stromberg and a Cat on an earlier model car? MG 22
P MGB Zenith water choke gasket needed MG 4
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
sparkydave Zenith auto choke coming loose Spridgets 2
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
bfitz Zenith Stromberg O ring question Other British Cars 8
C TR6 Zenith Strombers won't start when warm. Triumph 2
sparkydave Zenith auto choke coming loose Spridgets 3
Zimmycobra TR4/4A Zenith Stromberg questions Triumph 13
L zenith-stromberg carbs Lotus 11
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
W Zenith stromberg carbs Jaguar 3
A Zenith 175CD carbs Triumph 9
CZ_Dave Zenith Carb MG 13
eschneider TR4/4A TR4 Zenith-Stromberg CD175 tuning question Triumph 4
M zenith stromberg? Triumph 1
martx-5 Zenith Stromberg Carbs Triumph 4
M zenith stromberg 175cd Triumph 0
B Question- Spridget & MGB Zenith flanges? Spridgets 2
R Zenith Stromberg Running Lean - Up-date MG 1
R Zenith Stromberg Running Lean MG 7
Ofcalipka Zenith single carb problems MG 62
2wrench Anybody running a BP270 cam with Zenith carbs? Triumph 2
H conversion from Zenith to SU Triumph 5
M zenith float adjustment 1979 MG 1
glemon "Fixing" Zenith Stromberg Emission Control Carbs MG 4
I Zenith stromberg metering needle removal help Triumph 9
I zenith stromberg float brass plug removal help Triumph 14
I TR6 69 TR6 Zenith Stromberg carb help Triumph 1
J Zenith Stromberg question MG 4
C MGB 1979 MGB Zenith Stromberg Carburetor MG 3
Bret Yet another Zenith Stromberg replacement choice MG 6
jerrybny Front Zenith carb overflowing Triumph 20
S Zenith Stromberg Mixture Adjuster Restoration & Tools 13
G TR6 Zenith Stromberg [1973 TR6] help Triumph 5
mgbmedic Single Zenith Carb- Results MG 1
mgbmedic Single zenith carb is a joke... MG 19
sparkydave Fixing Zenith-Stromberg needle adjuster Spridgets 5
