TR6 Zenith Strombers won't start when warm.
Chirs C
I'm almost ready to finally get my '76 TR-6 smogged. (california, not exempt) It's got rebuilt 175CD-2SEVX carbs. The problem is it won't re-star after it is warmed up. It starts just fine if I let it sit over night. Any ideas ?
poolboy
Are you following the technique in the Drivers Handbook that's described in "Starting a Hot Engine" ?
If you are and you find the engine still won't start, it's probably a fuel/air mixture and or ignition timing problem that needs dialing in.
Fuel percolation will make the engine hard to start, but the hot engine starting technique will help. The once reluctant to start engine may run rough until enough of the fresh and cooler fuel gets pumped into the float chambers.
Geo Hahn
I would certainly double-check the mixture. Too rich Stroms will be hard to start hot and also bog down when you have to sit thru a long traffic light on a hot day.
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
Celtic 77 MGB Tinny Zenith air regulator MG 0
P Zenith Carburetor Triumph 2
V MGB Zenith Stromberg and a Cat on an earlier model car? MG 22
P MGB Zenith water choke gasket needed MG 4
P MGB Zenith 175 cd carb damper oil MG 2
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
sparkydave Zenith auto choke coming loose Spridgets 2
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
bfitz Zenith Stromberg O ring question Other British Cars 8
sparkydave Zenith auto choke coming loose Spridgets 3
Zimmycobra TR4/4A Zenith Stromberg questions Triumph 13
L zenith-stromberg carbs Lotus 11
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
W Zenith stromberg carbs Jaguar 3
A Zenith 175 CD's Triumph 19
A Zenith 175CD carbs Triumph 9
CZ_Dave Zenith Carb MG 13
R Zenith Stromberg CD 175 float replacements? Triumph 3
eschneider TR4/4A TR4 Zenith-Stromberg CD175 tuning question Triumph 4
M zenith stromberg? Triumph 1
martx-5 Zenith Stromberg Carbs Triumph 4
M zenith stromberg 175 cd Triumph 24
M zenith stromberg 175cd Triumph 0
M zenith stromberg 175 cd. Triumph 7
B Question- Spridget & MGB Zenith flanges? Spridgets 2
R Zenith Stromberg Running Lean - Up-date MG 1
R Zenith Stromberg Running Lean MG 7
Ofcalipka Zenith single carb problems MG 62
2wrench Anybody running a BP270 cam with Zenith carbs? Triumph 2
H conversion from Zenith to SU Triumph 5
M zenith float adjustment 1979 MG 1
glemon "Fixing" Zenith Stromberg Emission Control Carbs MG 4
I Zenith stromberg metering needle removal help Triumph 9
I zenith stromberg float brass plug removal help Triumph 14
I TR6 69 TR6 Zenith Stromberg carb help Triumph 1
J Zenith Stromberg question MG 4
C MGB 1979 MGB Zenith Stromberg Carburetor MG 3
H Zenith Stromberg CD 175 Too rich Triumph 7
Bret Yet another Zenith Stromberg replacement choice MG 6
jerrybny Front Zenith carb overflowing Triumph 20
S Zenith Stromberg Mixture Adjuster Restoration & Tools 13
G TR6 Zenith Stromberg [1973 TR6] help Triumph 5
mgbmedic Single Zenith Carb- Results MG 1
mgbmedic Single zenith carb is a joke... MG 19
sparkydave Fixing Zenith-Stromberg needle adjuster Spridgets 5
kbash Zenith Carb. MG 3
M Zenith-Strom Carb MG 4
