Windscreen Motor Repair
bandslak
I am trying to find where the yellow wire in the picture connects.
I don't think I have a problem in connecting the #1, #2, and E connections as shown on the attached diagram and (as yet) have not found a wiring diagram showing it.
I have looked at quite a few pictures that I had googled but could not see where/what the wire is attached to.
I have had comments that the yellow wire goes here or there but I believe I had used the yellow because it was what I had on hand rather than any attempt to follow the colour codes.
Thanks for any responses.
Bayless
The wiring diagram looks right for the DR2 motor. And I think you did supply the yellow wire.Its purpose is one side of the park switch or limit switch as Lucas calls it. Bad part is I can't say for sure which side, hot or earth. In either case though, I'm pretty sure it is an internal connection. Those wires in the diagram, 1, 2 and E are the only external connections on that motor. I'll try to check mine tomorrow to verify that it does go internal but I won't be able to tell where it connects.
B
bandslak
thanks very much for the reply, another forum indicated it is attached on the inside to the # 1 connection....
NutmegCT
BobHaskell
Bayless
Tom, I think I have that same Lucas manual on my computer. I studied it before answering above but could not determine where to connect that limit switch internally. I don't remember where I got the manual but it covers a lot of Lucas electrical devices. It includes a bunch of PDF files and has a HTML index to organize them. I wonder if Basil would like to post them for BDF. I'll check.
BobHaskell
I'm working on a similar site. Currently have Lucas Workshop Instructions, SU fuel pump and BMC/BL service articles uploaded to it. Have several Austin Service Journals to add. liblbc.info
W Windshield / Windscreen Wiper Motor Austin Healey 1
P Windscreen Washer Motor Austin Healey 7
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
RCarr Windscreen Glass Options Austin Healey 2
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
B Windscreen Pillar/Quarter Light Relationship Austin Healey 2
W Tudor windscreen washer bottles Spridgets 0
Popeye TR4/4A Tonneau snaps by windscreen Triumph 2
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
K TR2/3/3A I saw a 59 TR3 today with an aluminium windscreen! Triumph 5
A MGB MGB 1974 windscreen centre rod replacement MG 5
71TR6 TR2/3/3A New Windscreen Glass quality Triumph 6
Csarneson BN4 Windscreen Washer Jet Austin Healey 3
71TR6 TR2/3/3A TR3 windscreen frame corner bracket screw thread Triumph 9
LAW75 Repairing Windscreen Scratches Austin Healey 10
Healey Nut BT7 Windscreen Pillars Austin Healey 4
MGTF1250Dave T-Series TF Windscreen Wiper wiring MG 4
G windscreen problem Spridgets 1
T Windscreen wiper wheelbox rubber shaft seal Austin Healey 4
M Windscreen Wipers Parking Spridgets 4
M General MG Magnette windscreen washers MG 1
B TR2/3/3A Windscreen galss replacement Triumph 5
R Windscreen Glass Austin Healey 6
hondo402000 TR6 TR6 Windscreen remove and now windows dont fit Triumph 3
J Wanted TR3 Windscreen guide plates Triumph Classifieds 7
R BJ8 Windscreen Change Austin Healey 2
C Folding Windscreen Austin Healey 20
P For Sale tr6 windscreen Triumph Classifieds 0
4tecdog Windscreen rail to hood seal Austin Healey 11
bugedd Measurement of windscreen glass Spridgets 7
K TR2/3/3A Windscreen seal Triumph 16
4tecdog Frogeye Windscreen Spridgets 3
Jim_Gruber Free Spridget Windscreen available - Dayton OH Spridgets 3
K Windscreen Washer Question Austin Healey 26
M TR4/4A Windscreen capping Triumph 0
G TR4/4A Inside Windscreen Capping Triumph 6
B Windscreen washer pump upgrade Austin Healey 10
P TR2/3/3A TR3A Scuttle/Windscreen Stanchion questions Triumph 12
CJD TR2/3/3A Windscreen Tenax Triumph 22
B TR6 Windscreen removal advice Triumph 10
NutmegCT T-Series windscreen glass? MG 8
TRMark TR4/4A Installing a new windscreen Triumph 9
Bugeyze BN4 Windscreen Shims? Austin Healey 13
bugedd Windscreen glass question Spridgets 0
TRMark TR4/4A Top Tint Windscreen Triumph 0
bugedd Windscreen and top fitment issue Spridgets 16
B Mini Windscreen Wiper Parking British Motor Corp 3
O TR2/3/3A Windscreen Triumph 8
Jim_Gruber NOS 10 Post BE Windscreen on E-Bay right now - NFI Spridgets 3
