When you get to the angle irons in the lower corners, watch for the screw head style. It may be flat, Phillips, or torq. If it looks like Phillips, but has 4 tic marks between the cross, it is a special and needs the " torq" #2 bit. Phillips will make mess of same. Some lube may be a must.
Le
