When you rebuild your car double check everything
G
I have a friend rebuilding a TR6 from parts and a shell. He's spent a ton of cash, put in a lot of hours, and it's starting to come together now.
He's been at this thing for the last 5 months - I helped him put the engine/box in a couple of weeks ago, and I figure he's got a couple more months before it fires up and goes down the road.
I got a call this week - he forgot the dowels for the pressure plate. Just spent the afternoon pulling the box to fit them.
That's a mean job for something so stupid. I wish he'd read the manual before bolting the box to the engine...
/ubbthreads/images/graemlins/frown.gif
Moral: Check check and check again.
Deleted member 3577
I read somewhere that someone put everything back together then noticed the clutch disk sitting on the work bench.
Sounds all too familiar. I'm the number one guy to leave some small cheapo insignificant part out upon reassembly, so's I always, always, always, always doublecheck 3 things:
The shop manual
The parts bin (that was stored in order of removal)
The new parts (gaskets and o-rings and other such collected new parts that have to go in)
Banjo
#5 oil filter. We've got a car at work right now that made it about 3 or 4 miles out of a local "fast lube" joint after they did not put a new filter on it(and they took the old one off). And I suspect no oil either as the underside isen't as oil coated as you'de think.
Anyway, now it's got 9500 miles and a bad motor. Yup that's less than 10k miles. On a Toyota, that would be oil change number 2. ( our interval is 5000)
But they saved at least 2 bucks by going to the lubie station. /ubbthreads/images/graemlins/thumbsup.gif
[ QUOTE ]
#5 oil filter. We've got a car at work right now that made it about 3 or 4 miles out of a local "fast lube" joint ....
[/ QUOTE ]
Don't idiot lights work anymore???? /ubbthreads/images/graemlins/crazy.gif /ubbthreads/images/graemlins/confused.gif
At least when my cousin left the drain plug out he noticed the puddle under the car as he backed away and thought "Where'd that come from?" 'course, he did put oil in it...
Aa quick lube that saves on filters and oil... bargain prices, no problem.... /ubbthreads/images/graemlins/jester.gif
Simon TR4a
Re: When you rebuild your car double check everyth
Something to consider would be to mark with a magic marker all the bolts/nuts that have had a final tightening.
Simon.
G
[ QUOTE ]
[/ QUOTE ]
Only to encourage them to build better ones.
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
B Pertronix and Dist Rebuild - Car not starting Austin Healey 63
Carlbanan56 MGB MGB rear break rebuild MG 6
6 Master Cylinder Rebuild Spridgets 6
wangdango Carb Rebuild Necessity Austin Healey 3
drooartz MGB Front suspension rebuild is next MG 57
KVH General Tech Rebuild Report Triumph 6
KVH General Tech Initial Start Up After Rebuild Triumph 23
KVH General Tech More Engine Rebuild Questions Triumph 15
G MGB '71 MGB Front End Rebuild MG 2
drooartz MGB A nice milestone since the rebuild MG 3
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
I Bugeye valve rebuild suggestions Spridgets 8
D MGB 25D dizzy rebuild MG 29
R Rib Case rebuild... Spridgets 5
K TR2/3/3A Further to brake caliper rebuild.... Triumph 2
woolfman C39 vs C40 Dynamo rebuild/parts Spridgets 0
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
C TR2/3/3A TR3A clutch/brake cylinder rebuild Triumph 4
B TR2/3/3A TR3a steering box rebuild Triumph 19
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
TAS525 TR2/3/3A Steering Box Rebuild? Triumph 19
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
mrv8q TR2/3/3A Brake master cylinder: rebuild or replace? Triumph 9
RJS General TR TR4A Seat Rebuild Triumph 12
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
J Transmission and Overdrive Rebuild Austin Healey 6
J TR6 TR6 Differential Rebuild question Triumph 6
Tr3aguy TR2/3/3A Rear Axle Rebuild Triumph 3
pkmh BJ8: Upper Trunnion Rebuild [Of Continuum] Austin Healey 9
jfarris TR2/3/3A Happy with my Paltech Carb rebuild Triumph 8
6 Smith heater rebuild Austin Healey 8
J Front Suspension Rebuild Austin Healey 16
EWD TR6 74 TR6 - Carbon canister rebuild Triumph 2
R TR6 Gearbox rebuild issues Triumph 8
J Engine rebuild Austin Healey 4
S TR4/4A TR3/4/4a Transmission rebuild question Triumph 7
R TR2/3/3A 1961 TR3A Master Cylinder[s] Rebuild Kits Triumph 4
B BJ7 back end rebuild Austin Healey 1
M TR6 Clutch Master Rebuild: That Crazy Wavy Washer Triumph 1
classicmechanic Amazon engine rebuild pics Other Cars 6
W XKs Motorsport gearbox rebuild fiasco Jaguar 5
M 948 Engine Rebuild Question Spridgets 0
6 Master Cylinder Rebuild Help Please Spridgets 3
