Wheel/tire Sizing Revisited
Mickey Richaud
I know there's an earlier thread, but can't seem to find what I need to know.
I've got some 5.5" x 14" rims with 3/4" more positive offset (mounting flange is further away from the back of the rim) than the Rostyles. This puts the tire that much closer to the wheel well. Anybody know the range of choices for tires that will fit?
By the way, these are from a Mitsubishi, and believe it or not, the stock Rostyle center caps fit!
Mickey
With that much offset, I would expect 175/70 to be the tire of choice. 195/65 would be the maximum I'd run on the rim itself.
Thanks, Steve - that's helpful. I'm not too interested in going much wider than stock, but did want a bit more patch, and wanted to fill up the wheel wells without rubbing. With "only" 3/4" more offset, I was hopeful that I wouldn't be too limited.
Mickey
prb51 BN6 Wheel/Tire Combo Austin Healey 26
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
AUSMHLY Wheel Tire Camber Austin Healey 57
Raymond MGB Wire Wheel Tire Mounting MG 0
S General TR Wire Wheel New Tire Installation Question Triumph 11
bugedd Wheel and Tire Question Spridgets 34
Kirk_Fisher TR4/4A Tire and wheel question Triumph 13
6 Spitfire Tire bumps wheel well on spit mk3 Triumph 5
O TR2/3/3A TR3 Wheel Swap and Tire Size Triumph 10
N Wheel and tire shopping. Spridgets 3
60TR3A What Size Tire is Ideal for a 15" X 5.5" Wheel? Triumph 29
L Wheel and tire sizes for the 3000 Austin Healey 8
T Wheel rim corrosion at tire bead contact Austin Healey 1
ekamm TR2/3/3A 3a steel wheel tire size? Triumph 14
HAN8L1965 Length of Steel Wheel Tire hold town Spridgets 7
T TR4/4A TR4A wire wheel tire size & powder coating? Triumph 18
mikecyc72usa Wheel and tire questions Triumph 11
M old tire & wheel Spridgets 9
W tire and wheel safety---pass it on! Restoration & Tools 0
T TR4/4A largest tire and wheel combo?? for a stock tr4 Triumph 10
glemon MGB MGB Tire and Wheel Sizes MG 14
ModifiedBJ7 Wheel Wells/Wheel & Tire Size Austin Healey 13
NutmegCT Stupid tire/wheel question. Triumph 18
David_K HELP! BJ8 Wire Wheel/Tire Decision Austin Healey 11
angelfj1 Wheel/Tire Project Up-date Triumph 8
H Wire Wheel Conv in Albuq NM: Need a Good Tire Shop Austin Healey 4
H Wire Wheel Conv in Albuq NM; need a good tire shop Triumph 3
H 15 x 6.70 Size Tire Ok for 100-6 Wire Wheel? Austin Healey 3
69MGC Wheel and Tire question MG 3
KVH TR4/4A TR4 Wheel and Tire Sizes Triumph 3
H BJ8 wire wheel and tire size Austin Healey 7
Earl Wheel and Tire sizes Triumph 6
S Minilite Wheel and Tire Size Spridgets 3
R Wheel/tire bubble balancers MG 16
T TR6 Steering Wheel Lock Triumph 2
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
D Removing the steering wheel hub Spridgets 12
Todd78d Wire wheel cleaner Spridgets 1
zoohow wheel spacers Racing 1
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
K 1068 mkIII wire wheel rub Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
K TR6 TR 6 Wheel Studs Triumph 10
AUSMHLY Front Wheel Spin Drag Austin Healey 6
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
Editor_Reid Wrapped Steering Wheel Austin Healey 9
60BN7 Rear Wheel Opening Austin Healey 9
