What Lube to use
DNK
So I dismantled the plenum on the Wedge to be prettified.
Now when I go to put the butterfly shaft back in. What should I lube, grease, or what ever the surface of the plenum where the shaft rotates?
Anti seize?
LD-Ordie Series II gear lube question Rover / Land Rover 3
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
Michael Oritt Steering box lube Austin Healey 22
S Ignition advance weights - how to lube? Austin Healey 5
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
D TR2/3/3A lube equivalents Triumph 3
JFS TR2/3/3A Wiper Cable Lube Triumph 5
S TR2/3/3A lube for upper A bushings Triumph 2
R TR2/3/3A Lube for steering box, transmission and rear end Triumph 6
N Best lube for a Datsun gearbox?? Spridgets 6
K TR2/3/3A Penrite semi fluid steering box lube? Triumph 14
R TR2/3/3A Oil gun for 'Propeller shaft" lube Triumph 9
D TR2/3/3A Universal Joint Lube Question Triumph 8
tomshobby General TR making it easy to lube door hinges Triumph 0
KVH General Tech Assembly Lube Triumph 2
KVH General Tech Assembly Lube and Zinc and New Cam--TR4A Triumph 7
3798j LocknLube Restoration & Tools 0
S TR6 Trunnion lube Triumph 6
Griz New Engine Pre-lube BJ7 Austin Healey 13
Rut Steering column lube Spridgets 2
N lube starter gears? Triumph 6
RickB 78 Midget steering rack lube? Spridgets 4
D Grease nipples to lube the back of the rear spring, BT7 Austin Healey 7
J Wedge TR 7 Differential Lube Triumph 3
6 Dif lube? Spridgets 8
KVH TR4/4A TR4A Differential Lube Triumph 5
D Lube in OD gearbox MG 15
sjuengst Gear lube leaking from hub Austin Healey 8
RJS Correct Lube for Steering Box/Rack? Triumph 1
71tr How to pump oil through a lube gun? Triumph 4
Sopwith_Camel lube me! Spridgets 20
glemon Polyurethane Bush Lube Triumph 8
Sopwith_Camel brake lube Spridgets 5
T Correct grease / lube for Poly bushings Triumph 10
sparkydave Steering rack lube Spridgets 19
Brosky Tach cable lube Triumph 4
tomshobby A way to lube the clutch pedal pivot. Triumph 1
DNK Brake Lube Triumph 5
Bruce_B Datsun 5-speed Gear lube recommendations needed Spridgets 9
71tr Clutch Lube Triumph 8
D Pre-Lube Systems Triumph 11
J Spitfire Differential gear lube level 78 Spitfire Triumph 5
YankeeTR Quality Lube Products... Triumph 1
tahoe healey lube chart Austin Healey 6
71tr clutch component lube Triumph 0
BIBBER TRANSMISSION LUBE CAPACITY Spridgets 3
fmichaels tranny lube Spridgets 16
G How do I separate my drive shaft to lube splines Triumph 4
Lin Front suspension assembly lube Austin Healey 1
A Lube for poly bushings ?? Triumph 5
