TR2/3/3A lube equivalents
deuce
Hi folks.. has there ever been a list compiled for compatible lube products for my tr3a? IE engine oil, gearbox, diff/rear axle..like the Recommended Lubricants page in the shop manual. Thanks in advance
We have discussed and re-cussed this topic many times. The problem is that the choices are almost entirely based on FUD and personal opinion. So, there are almost as many conflicting opinions as there are members of this forum; and very little consensus.
That said, here are my opinions, based on many personal experiences and hundreds of thousands of miles covered in a TR3/A under pretty harsh conditions:
Crankcase : Valvoline VR1 (racing) oil 20W50 unless you live in a colder climate and/or have a freshly rebuilt engine.
Gearbox & OD (if fitted) Redline MT-90
Rear axle and steering box : Valvoline SynPower 75W90 gear oil
Brakes and clutch: any fluid rated DOT 5 (not 5.1). Brand not important, I usually buy from TRF just because their price is good (and I like to support TRF).
Thank you sir. I'm still looking at a completely redone rolling frame, though I have a newly rebuilt engine I want to mount. Right now I have the cover off the differential..wiped it out and wanting to flush it out a little so looking for a suitable gear oil. Seems that SynPower is as good a start as any. Yes, this subject is scattered all over the site. I was just wondering if anyone had put together a page similar to the pages in the shop manual where there are several compatible choices. Again, thanks for your reply.
I've followed Randall's recommendations with my recently-rebuilt drivetrain, with a minor exception: I run straight 40W Valvoline VR1 in the motor. I've found the gearbox and OD respond well to Redline's MT-90 (very smooth shifting).
LD-Ordie Series II gear lube question Rover / Land Rover 3
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
Michael Oritt Steering box lube Austin Healey 22
S Ignition advance weights - how to lube? Austin Healey 5
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
JFS TR2/3/3A Wiper Cable Lube Triumph 5
S TR2/3/3A lube for upper A bushings Triumph 2
R TR2/3/3A Lube for steering box, transmission and rear end Triumph 6
N Best lube for a Datsun gearbox?? Spridgets 6
K TR2/3/3A Penrite semi fluid steering box lube? Triumph 14
R TR2/3/3A Oil gun for 'Propeller shaft" lube Triumph 9
D TR2/3/3A Universal Joint Lube Question Triumph 8
tomshobby General TR making it easy to lube door hinges Triumph 0
KVH General Tech Assembly Lube Triumph 2
KVH General Tech Assembly Lube and Zinc and New Cam--TR4A Triumph 7
S TR6 Trunnion lube Triumph 6
Griz New Engine Pre-lube BJ7 Austin Healey 13
Rut Steering column lube Spridgets 2
N lube starter gears? Triumph 6
RickB 78 Midget steering rack lube? Spridgets 4
D Grease nipples to lube the back of the rear spring, BT7 Austin Healey 7
J Wedge TR 7 Differential Lube Triumph 3
6 Dif lube? Spridgets 8
KVH TR4/4A TR4A Differential Lube Triumph 5
D Lube in OD gearbox MG 15
DNK What Lube to use Triumph 0
sjuengst Gear lube leaking from hub Austin Healey 8
RJS Correct Lube for Steering Box/Rack? Triumph 1
71tr How to pump oil through a lube gun? Triumph 4
Sopwith_Camel lube me! Spridgets 20
glemon Polyurethane Bush Lube Triumph 8
Sopwith_Camel brake lube Spridgets 5
T Correct grease / lube for Poly bushings Triumph 10
sparkydave Steering rack lube Spridgets 19
Brosky Tach cable lube Triumph 4
tomshobby A way to lube the clutch pedal pivot. Triumph 1
DNK Brake Lube Triumph 5
Bruce_B Datsun 5-speed Gear lube recommendations needed Spridgets 9
71tr Clutch Lube Triumph 8
D Pre-Lube Systems Triumph 11
J Spitfire Differential gear lube level 78 Spitfire Triumph 5
YankeeTR Quality Lube Products... Triumph 1
tahoe healey lube chart Austin Healey 6
71tr clutch component lube Triumph 0
BIBBER TRANSMISSION LUBE CAPACITY Spridgets 3
fmichaels tranny lube Spridgets 16
G How do I separate my drive shaft to lube splines Triumph 4
Lin Front suspension assembly lube Austin Healey 1
A Lube for poly bushings ?? Triumph 5
F Tranny Lube? Spridgets 10
