Dif lube?
61frogeye
I am in the process of servicing oil/grease/lube my (new to me) BE. What do you use in the differential and what grease do you use for the grease fittings?
Thanks,
Dave
Hi Dave,
For the differential, 90 wt gear lube. Adjust weight for your climate. Synthetic is OK too. The gearbox is specified for 30 weight non-detergent motor oil, but you can use whatever you in the engine. Do not use gear oil in the transmission. As far as grease, I think I'd use the synthetic type that is available today.
Gerard, I am filling a diff in the next couple of days and was planning to use 90wt. Your comment about making an adjustment for climate got me to thinking. I live and drive in southern Cal. and wondered if I should go to 100wt since it is over 100 degrees for 6 months a year and it never gets below 40. I use Royal Purple lubricants in the diff and trans. What do you think?
Westfield XI,
Below are specs for the Datsun 5 speed gearbox. I would use it as a "rule of thumb" for other applications regarding temperatures.
I've used Redline MTL, a very good choice. I've not used Royal Purple, but heard good things from others.
Datsun Spec is 2.5 pints of API GL4 (or superseding) classification -
Viscosity @ Outside temperature range
+50F to -20= 75W,
+86F to -20= 80W
+104 to -20= 75W-90/80W-90,
Between +14 and +86 = 85W,
+32 to +104= 90,
+50 to +104= 140
Recommended service is "Inspect @ 15,000 miles"
Gerard said:
Hi Dave,
Hey Gerard,
I was at the local O'Reilly's and Advanced today, they did not have a straight 90wt gear lube. They had Castrol and other brands but they were spec'd as 75/90 or 80/90. If those are not a good idea (my climate extremes are generally 0f to 95f) got any brand names that still make a straight 90 that I should look for?
Thanks
Gerard said:
Westfield XI,
+50F to -20= 75W,
+86F to -20= 80W
+32 to +104= 90,
+50 to +104= 140
Thanks, but what about that diff that I will be filling soon? There is no issue with my g/b.
Dave,
I'm not an expert on oils, but I think I'd go with a 75w-90 synthetic. That seems ideal for the temperature range.
CJD TR2/3/3A Lockheed Dif seals Triumph 5
kodanja Whats the Dif'? Triumph 12
prb51 TR2/3/3A TR3 Dif Pinion seal and speedy sleeve Triumph 12
Aldwyn Dif Oil Triumph 8
LD-Ordie Series II gear lube question Rover / Land Rover 3
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
Michael Oritt Steering box lube Austin Healey 22
S Ignition advance weights - how to lube? Austin Healey 5
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
D TR2/3/3A lube equivalents Triumph 3
JFS TR2/3/3A Wiper Cable Lube Triumph 5
S TR2/3/3A lube for upper A bushings Triumph 2
R TR2/3/3A Lube for steering box, transmission and rear end Triumph 6
N Best lube for a Datsun gearbox?? Spridgets 6
K TR2/3/3A Penrite semi fluid steering box lube? Triumph 14
R TR2/3/3A Oil gun for 'Propeller shaft" lube Triumph 9
D TR2/3/3A Universal Joint Lube Question Triumph 8
tomshobby General TR making it easy to lube door hinges Triumph 0
KVH General Tech Assembly Lube Triumph 2
KVH General Tech Assembly Lube and Zinc and New Cam--TR4A Triumph 7
S TR6 Trunnion lube Triumph 6
Griz New Engine Pre-lube BJ7 Austin Healey 13
Rut Steering column lube Spridgets 2
N lube starter gears? Triumph 6
RickB 78 Midget steering rack lube? Spridgets 4
D Grease nipples to lube the back of the rear spring, BT7 Austin Healey 7
J Wedge TR 7 Differential Lube Triumph 3
KVH TR4/4A TR4A Differential Lube Triumph 5
D Lube in OD gearbox MG 15
DNK What Lube to use Triumph 0
sjuengst Gear lube leaking from hub Austin Healey 8
RJS Correct Lube for Steering Box/Rack? Triumph 1
71tr How to pump oil through a lube gun? Triumph 4
Sopwith_Camel lube me! Spridgets 20
glemon Polyurethane Bush Lube Triumph 8
Sopwith_Camel brake lube Spridgets 5
T Correct grease / lube for Poly bushings Triumph 10
sparkydave Steering rack lube Spridgets 19
Brosky Tach cable lube Triumph 4
tomshobby A way to lube the clutch pedal pivot. Triumph 1
DNK Brake Lube Triumph 5
Bruce_B Datsun 5-speed Gear lube recommendations needed Spridgets 9
71tr Clutch Lube Triumph 8
D Pre-Lube Systems Triumph 11
J Spitfire Differential gear lube level 78 Spitfire Triumph 5
YankeeTR Quality Lube Products... Triumph 1
tahoe healey lube chart Austin Healey 6
71tr clutch component lube Triumph 0
BIBBER TRANSMISSION LUBE CAPACITY Spridgets 3
fmichaels tranny lube Spridgets 16
