KVH
I realized after using plastigauge that as I removed each connecting rod cap I put lube on the crank and cap, figuring that's good enough without spinning the crank to do the other "hidden" half. I assumed the lube would do for the entire journal. Am I OK, particularly since I'll be running the oil pump to prime the pressure before starting anyway?
