Upgraded rod bolts for stock rods
robcadle
Hello,
I am just starting the engine rebuild on my BT7. The engine will be built as "fast road" with uprated cam, AL cylinder head, triple Weber's, etc. However, I don't anticipate tracking the car because I don't want to put a roll bar in. I plan to retain the stock crank and rods (although I may have the rods shotpeened)
I am planning to get uprated studs and hardware for the mains and head, but I haven't found any upgrade for the rod bolts. Denis Welch offers an uprated nut, which I suppose is better than nothing, but I'm wondering if there is any option for the rod bolts.
I have seen a couple posts refer to using ARP rod bolts. I checked ARP's web site and they do not list a rod bolt application for AH 3000 (then again, they don't list a head stud application, either, which Moss sells).
Any advice? I'm not very impressed with the stock connecting rod and the stress risers created by the anti-rotation grooves for the rod bolts, so maybe the bolts aren't going to be the first thing to go anyway. Still, these are highly stressed parts so I'd like to make sure to use as high a quality fastener as possible. If there is no upgrade fastener, are the parts Moss offers "good enough"?
Thanks for feedback,
Rob
You`ve probably alreadh acted or thought of it, but try phoning ARP. I`m getting a BE Sprite engine done and I`ll swear that we`ve got more ARP bits than the factory put in. Doug
SNClocks Upgraded Motor Mounts Spridgets 4
K What to do for coil bracket on upgraded generator? Austin Healey 8
Bob_Spidell 'Upgraded' Video Austin Healey 3
andrea ONE OLD GOOD BCF REMEDY upgraded Austin Healey 2
J TR4/4A TR4 Upgraded inlet manifold/valve cover question Triumph 42
johnrip Wedge TR7 upgraded 4 row radiator Triumph 4
N Rear Diff mounts upgraded Triumph 2
MGFever Upgraded Front Wheel bearings Spridgets 8
Bruce_B Upgraded Rear Axle Advice for '59 BE - Question Spridgets 11
2wrench TR6 Choice for upgraded shocks on TR6 Triumph 2
K TR2/3/3A TR3 upgraded cams & richer SU needles?Advice? Triumph 5
B Rod & Main Bearings Recommendations Austin Healey 10
W Correct Tie Rod Ends Spridgets 0
D Separating the piston from the connecting rod. Spridgets 9
KVH General Tech Connecting Rod Bearings Triumph 8
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
B For Sale Connecting Rod Bearings Austin Healey Classifieds 0
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
A MGB MGB 1974 windscreen centre rod replacement MG 5
S For Sale TR-3 Tie Rod Assembly for Sale Triumph Classifieds 0
DrEntropy Shift rod seal in an automatic? Jaguar 7
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
Healey Nut Cross Rod Correct Length Austin Healey 14
7 General TR Hot rod Triumph 0
Healey Nut BT7 Panhard Rod Austin Healey 28
Walter74 Steering Rod Installation Austin Healey 6
red57 Rod Bearing Clearances Austin Healey 4
BoyRacer Odometer Reset Rod Austin Healey 4
K TR2/3/3A Removal of tie rod end? Triumph 7
TRopic6 For Sale Vandervell .010 Rod Bearings, MG TB, TC, TD, TF [Partial set] MG Classifieds 0
R TR2/3/3A Throttle rod spring location Triumph 3
I Brake rod questions Spridgets 7
Y MK V rod bearings Jaguar 1
Jim_Stevens TR2/3/3A Bonnet Stay rod safety latch differences Triumph 5
Phil73 TR6 VERY tight Tie Rod ends Triumph 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
K TR2/3/3A Inner tie rod ball joint. Triumph 6
R Connecting Rod Big End Specification Austin Healey 4
John Turney The Panhard Rod is Supposed to be Straight, Right? Austin Healey 7
6 WTB +.040 piston with con rod for 2639cc Longbridge 100-6 Austin Healey 6
T TR6 Air vent rod connection Triumph 1
F TR2/3/3A Throttle linkage cross rod Triumph 4
K TR2/3/3A TR3 Tie Rod Sleeve Triumph 2
K Wanted TR3 Tie Rod Sleeve Triumph Classifieds 2
Rhodyspit75 Bugeye bonnet prop rod Spridgets 2
Michael Oritt Center rod, bracket and mirror info needed Spridgets 8
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
M TR2/3/3A Connecting Rod Locking Tab Deformation Triumph 15
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
Got_All_4 TR2/3/3A Inner tie rod ends Triumph 4
