Turn signal relay
Neff BT7
I believe my turn signal problem is related to the relay having gone bad. The Lucas part is stamped with #331170.
Anyone have access to this part?
Thanks.
Neff BT7
Wingtip
The good news is, Victoria British Sells them (or a reasonable facisimi) I asked them about it when I called on a different issue. The bad new is, they want $129.95!!!
However, (and I'm not a Healey expert so don't hold me to this, but...) In many cases, these old British relays are in cans and use "contacts" that often get dirty or gummy. Usually you can gently pry apart the can from its base and examine/clean the contacts and also look for any poor connections from the contacs or coil to the connectors. You can clean the contacts with a strip of light emory paper and also get some electrial contact cleaner from Radio Shack. The connectors on the base can be cleaned nicely with a pencil erasor and you should examine the connectors on the wires. If they are badly corroded, you should replace them. Just something to try before you submit to buying a new relay (you may have already done all this).
Hope this helps,
George
PS: If VB sells them, other places probably do also, so I'd call around for prices first.
Johnny
There's a great article in the Jan/Feb issue of Healey Marque, (Magazine of the AHCA) written by John Trifari, on this very subject. It's a two part article to be continued in the March issue. John did a wonderful job on this subject, including great photos. Maybe you can find someone in the AHCA (Austin Healey Club of America) in your area that will loan you the article. Or you can email John Trifari at (john4@home.net)
Johnny, 59bn7, 75mgb
Editor_Reid
Platinum
Hi Lynn,
If you're not in a hurry, you might try surfing eBay as they show up there occasionally, along with many other original Lucas electrical components. There are even a couple of sellers there who specialize in Lucas parts . Do a couple of searches and you'll probably find them. Just try not to get distracted with all of the other Healey stuff on there!
M Where is the turn signal flasher relay? Austin Healey 7
bt7tricarb Turn Signal Relay Austin Healey 11
Got_All_4 TR5/TR250 Annoying turn signal relay question Tr250 Triumph 7
Ed_K A bad brake/turn signal relay or ??? Austin Healey 9
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
K TR2/3/3A The horn and turn signal assembly. Triumph 3
KVH General TR Green Turn Signal Dash Indicator Triumph 8
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
6 Turn Signal Flasher Spridgets 8
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
B General MG Turn Signal Issue MG 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
M Europa turn signal problem Lotus 7
R Spitfire Turn signal wiring Spitfire Triumph 5
S TR2/3/3A Rear turn signal lamp and trim installation Triumph 5
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
R Turn Signal Knob goes off center Austin Healey 9
E MGB Turn signal bulb MG 5
Nelson Turn signal beeper. Spridgets 14
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
M TR6 Turn signal switch stalk Triumph 1
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
B Turn Signal Indicator Light Always Flashing Austin Healey 10
R TR2/3/3A The Turn Signal Challenge Triumph 2
TR3TR6 TR6 TR6 turn signal puzzle Triumph 11
S Turn signal nightmare ! Spridgets 4
S Turn signal nightmare ! Austin Healey 4
N Turn signal flasher?? Spridgets 8
J BJ8 Turn signal help needed. Austin Healey 6
PAUL161 T-Series Turn Signal Flasher MG 8
glemon General Tech Turn Signal Issue Triumph 12
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
R Turn signal switch [trafficator] Austin Healey 1
R TR2/3/3A Turn signal wiring Triumph 1
S Bizarre turn signal issue Austin Healey 10
bighealeysource Turn signal gremlins on BN2 Austin Healey 2
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
bighealeysource Turn signal issues Austin Healey 6
J LED Brake / Turn Signal Austin Healey 4
77MidgetMkIV High Beam/Turn Signal switch issue? Spridgets 21
M Turn signal problem Austin Healey 3
R MGB Turn signal help 67 MGB MG 2
J Horn/turn signal rotate independently of the steering wheel. FORUM Navigation Questions 1
