General TR Transmission Problem
KVH
KVH
While driving slowly I suddenly noticed that I couldn't shift into first or second gear. It was as if the shifter got stuck or was hitting some kind of obstruction. I had a similar issue last year, and thought it went away. But it's back. I can, however, shift into first and second if I slightly lift up on the shifter, somewhat as if I'm going into reverse.
When this last happened I disassembled the shifter and found the anti-rattle button missing. I assumed it had been dislodged and was impeding the shift lever, then dropped out. I no longer think that was the case.
So, my question is whether anyone has an idea here. Do the shift forks get loose or out of line? Would a bad syncro cause the need to pull up on the shifter?
Thanks all.
This doesn't sound like an internal problem with the shifting forks. I'd say your problem is with the shifter and how it interfaces with the shift rods. I'd have the shifter out and have a look. I can't imagine what the problem is, but again I don't think it's internal to the transmission.
I think you're right. I can feel something down in the shifter area. It's got to be something I did wrong with the button or spring, or something else down there, and I just need to find it.
B TR4/4A Transmission Input Shaft Clearance Problem Triumph 16
D TR2/3/3A TR3 Overdrive to transmission mating problem Triumph 8
DornTRoriginal TR2/3/3A Transmission Installation Problem TR 3A Triumph 8
D Transmission Problem Triumph 6
Baz Found the transmission problem....... Spridgets 0
Paulus TR6 TR6 Speedometer problem in transmission housing Triumph 5
Slider748 TR6 TR6 transmission removal problem Triumph 12
S TR4/4A TR4 Transmission Problem Triumph 5
M Transmission Problem '78 Spridgets 4
G Wedge TR7 Transmission problem Triumph 4
B transmission/clutch problem Spridgets 5
J Transmission Problem... Restoration & Tools 7
mctriumph Wanted Tr 3/Tr6 transmission kit interest Triumph Classifieds 1
G TR6 TR-6 Engine and transmission. Triumph 6
mctriumph For Sale All the rights and Tooling for Eaglegate transmission Kits Triumph Classifieds 0
S For Sale FREE - TR3 engine and transmission Triumph Classifieds 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
C TR6 Transmission Number Meaning Triumph 5
R 100-4 Transmission Austin Healey 1
J TR4/4A TR4A automatic transmission conversion Triumph 6
Popeye TR4/4A Transmission noise - intermittent Triumph 22
D XK150 Transmission Input Shaft Jaguar 1
A TR2 Transmission overhaul Restoration & Tools 0
E General MG Transmission Fluid Level MG 2
B Transmission Gear Lockouts Austin Healey 8
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
AUSMHLY Transmission Noise Austin Healey 11
T Looking for "BillMs rear transmission mount" Spridgets 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
bighealeysource Side-Shift Transmission Austin Healey 13
D transmission conversion Other British Cars 1
PAUL161 T-Series Original transmission sold MG 2
KVH TR4/4A Assembling Transmission to Engine--Vice/Versa Triumph 4
BritBite Transmission Repair Austin Healey 8
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
N Sprite "Ribcase" Transmission Austin Healey 3
AUSMHLY Transmission Sliding Hub Plungers Austin Healey 9
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 2
