TR6 TR6 heat insulation recommendations
tdskip said:
Where did you guys install extra heat insulation on your TR6 to help keep the interior comfortable?
<span style="color: #990000">I used aluminum faced insulation everywhere under carpet
plus I insulated the door interiors. It makes quite a bit of difference.
d </span>
I found the original "felt" pads and carpet worked just fine, and this in SoCal driving...
I have seen guys glue in exotic foil-faced insulation (not cheap) and have always wondered how they can sleep at night, knowing that moisture is our biggest enemy and can/will creep in between this stuff and <span style="color: #FF6600">rust</span>! I, too, like the jute stuff, just happy when it finally quits "shedding."
Besides, aren't these cars <span style="text-decoration: underline">supposed</span> to get hot on the floorboards?
I wrapped the exhaust pipes with header tape, and installed fatmat which I guess is that exotic foil-faced insulation. BTW I sleep very well at night. :yesnod:
One fifty foot roll will do both pipes from the manifold connection to the cruciform. I used stainless steel tie wraps to hold in place and painted with heat restraint paint to keep that dreaded moisture away. Purchase off of ebay for the best price.
I put foil faced insulation on the underside of the transmission tunnel with 3M adhesive, and on the inside face of of the trunk panel by the gas tank. Under the carpets I used synthetic jute fabric (its like having fleece under the carpets)for the reasons others have mentioned...it will not trap moisture. Just as important IMHO, is to get a tight seal around the transmission tunnel seams, as significant heat comes in this way. I used a rubber strip kit from the big three then sealed the edges with the 3M body sealing putty strips as recommended in earlier threads. This has made a big difference
Cheers,
Whereyat, Safari. Nice to hear from you. Do you go to the Delgado show? Good to see another Louisianan on the forum.
I attached the foil faced insulation with Velcro strips
to the floor so these is plenty of space for air to
circulation.
Insulating inside the doors made a world of difference
in lowering the road noise factor and heat.
d
I am in Algiers. I did make the show but not with my car. I had just purchased the car and hadn't picked it up yet. I had to get a trailer as the PO had parked the car 7 years ago with a fuel leak. I have gotten the car running which took 45 min. and another 4 weeks to get the clutch changed. I have made a pass through the brakes, mounted Pirelli P4 tires and did get her inspected. I hope all my supension parts arrive tomorow so i can start on getting all the old rubber out and new bushing and springs in. I have the interior out as I want to get the all the mechanical things out of the way.
Pictures of on going work.
Back to the Delgado show, I did see a few old friends at the show and some new ones Poolboy being one. It was great to see all the cars if you were there I bet I have a picture of your car.
I hope to make the August final Friday in Covington with the wife, which is the reason for the heat shielding.
Yourself, poolboy, and myself will have to plan a drive together around the north shore.
Safari
Word of Caution. I insulated the under side of the transmission cover with the foil faced insulation (foil facing out) and the first time I ingauged the overdrive it fried the wires. The foil came in contact with the switches on top of the transmission. I used the foil face insulation to cover all the floor and in the spare tire well. It does keep the heat down.
Joe
EWD TR6 Sound/Heat Mat installation - 74 TR6 Triumph 14
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
tr6web TR6 TR6 Manifold gasket help Triumph 1
mctriumph TR2/3/3A R&D completed on Tr6 fan conversion Triumph 2
Hawk813 TR6 TR6 Brakes Triumph 5
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
Charlypm For Sale 69 Triumph TR6 Racecar Triumph Classifieds 1
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
AngliaGT ANOTHER TR6,& an MGB Spotted 0
A For Sale 1974 TR6 Triumph Classifieds 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
