TR6 TR6 broken diff mount
Gary_Goldsborough
New to the group; Greetings all. I just got a 76 TR6 that has a broken differential mount. I understand this is a commonm problem. Have any of you had to deal with this? Any suggestions to avoid removing body from frame to repair it?
Thanks,
I have the same issue with my 6. The body is not all that bad except the sills and some of the frame so I can't justify a frame off repair unless I had the $$$. John Burket, from Triumphworks (www.triumphworks.com), in Claysburg, PA can handle this. He has a special jig set up to repair frames with the body on. His prices are on the web site too.
My name is on his list. Unfortunately, it's long. He said he'll probably get to it in the Spring. Anyway, maybe try him or call him to see what he thinks. You're a long way from PA, but maybe he's worth talking to.
HeyGary,
It seem you have most of it apart already , so the rest is getting a welder ( unless your equiped ) & making plates from the attatched templates. It's important to drill some holes in the plates to allow air flow & paint all the new steel & welds.
  • 147523-DifferentialMountReinforcementsTemplate.pdf
M TR6 1973 TR6 - broken choke cable Triumph 6
TomChar TR6 '74 TR6 - Broken Top bow Triumph 1
W TR6 broken bleeder on rear brakes tr6 Triumph 12
A TR6 TR6 Front lower wishbone mount [rear] broken Triumph 1
2wrench TR6 '74 TR6 Broken speedo cable Triumph 1
tr6web TR6 TR6 Manifold gasket help Triumph 0
mctriumph TR2/3/3A R&D completed on Tr6 fan conversion Triumph 2
Hawk813 TR6 TR6 Brakes Triumph 5
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
Charlypm For Sale 69 Triumph TR6 Racecar Triumph Classifieds 1
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
AngliaGT ANOTHER TR6,& an MGB Spotted 0
A For Sale 1974 TR6 Triumph Classifieds 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
