TR3 seat frame issue
BritCars54
Member
Is there any other option for mounting the seat/spring to the seat frame on a TR3? Very difficult to have the rods on the bottom of the spring assembly catch the riveted clip of the seat frame, and does not seem very stable.
AEW
I think that's about it... tip/push/sit. You must have redone the upholstery and now it's a tight fit??
B
BritCars54
Member
The upholstery has definitely been redone. Does not seem to catch and may need to open up the clips a bit. Thanks.
J TR2/3/3A TR3 Rear seat Triumph 11
B Wanted TR3 seat frames repairable Triumph Classifieds 1
T Wanted TR3 Seat Frames and Seat Rails Triumph Classifieds 3
tr3guy TR2/3/3A New TR3 Seat Rail Glides Triumph 3
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
A TR2/3/3A Tr3 Seat Belts Triumph 3
T TR2/3/3A TR3 Seat Questions Triumph 10
M TR2/3/3A 1956 TR3 ocasional seat Triumph 10
Tinkerman TR2/3/3A 1960 tr3 a seat tack strips Triumph 19
luke44 TR2/3/3A TR3 Which Seat flips? Triumph 11
B 60 TR3 Seat Belts Restoration & Tools 0
J TR2/3/3A TR3 seat patterns Triumph 9
M TR2/3/3A TR3 seat rebuild Foam VS Springs Triumph 7
mountainman TR2/3/3A TR3 Rear Seat Triumph 3
mountainman TR2/3/3A TR3 Back Seat Support Brackets Triumph 3
E TR2/3/3A TR3 seat track width Triumph 10
M TR2/3/3A TR3 Seat Rails Triumph 10
MGTF1250Dave TR2/3/3A TR3 Optional Rear Seat Triumph 22
R TR2/3/3A TR3 seat belts Triumph 7
CCURTISS Removing Seat Track Screws TR3 Restoration & Tools 3
PeterK TR2/3/3A TR3 seat rebuilding with foam. Triumph 4
fad64b TR2/3/3A TR3 seat back padding? Triumph 1
AngliaGT TR2/3/3A 3 Seat TR3? Triumph 25
fad64b TR2/3/3A TR3 seat redo Triumph 17
martx-5 TR2/3/3A Seat Belts in TR3 Triumph 41
TRclassic3 TR2/3/3A TR3 seat comfort Triumph 3
D TR2/3/3A TR3 seat rebuild Triumph 11
bluemiata90 TR2/3/3A tr3 seat slide rail locations Triumph 3
martx-5 TR2/3/3A Problem with TR3 Seat Triumph 9
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
