TR2/3/3A TR3 Rear Seat
mountainman
I have a 59 Tr3 com#ts39379l I need the seat supports for the rear seat. Does anyone have their rear seat out so that they could give me the measurements and angles so I might make a set. Or even better have a set they would sell me?
Thanks
Greg
TR4nut
Greg-
I have the same need. A BCF member several months ago sent me a copy of a how to with dimensions for the brackets - sorry I'm bad with memory and names otherwise I'd give direct credit. PM me your email and I'll try to scan and send it to you if you want it. As I recall, the supports are pretty simple, I think made with 1.5" flat stock.
Randy
mountainman
mountainman
Hey John,
I have sent you a pm.
J TR2/3/3A TR3 Rear seat Triumph 11
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
MGTF1250Dave TR2/3/3A TR3 Optional Rear Seat Triumph 22
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
Donald1107 TR2/3/3A TR3 Rear Shocks Triumph 11
B Wanted TR3 Hardtop Rear Stiffener Brackets Triumph Classifieds 0
K For Sale TR3 rear rebound brackets Triumph Classifieds 0
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
K For Sale TR3 rear cockpit center capping Triumph Classifieds 0
J Wanted Need tr3 rear axle housing Triumph Classifieds 0
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
A TR2/3/3A Newbie wrestling with TR3 rear wheel studs Triumph 3
Tinkerman TR2/3/3A TR3 A REAR WING BOLTS order of assembly? Triumph 3
Got_All_4 TR2/3/3A Tr3 rear differential seal Triumph 7
J TR2/3/3A Tramp bar for rear of TR3 or?? Triumph 7
mgedit TR2/3/3A Steady Springs Rear Brakes 56 TR3 Triumph 0
jfarris TR2/3/3A Wanted - TR3 Monza Muffler - Rear Section Only Triumph 1
M TR2/3/3A TR3 overdrive trans rear speedi sleeve Triumph 6
K TR2/3/3A TR3 Exhaust header's proximity to rear of generator? Triumph 4
1937dodge TR2/3/3A Anyone have any photos of TR3's sporting rear finned aluminum brake drums? Triumph 8
T TR2/3/3A TR3 Rear wheel cylinder attachment clips Triumph 6
mgedit TR2/3/3A Rear Drum Brakes 56 TR3 Triumph 2
rckuhlman TR2/3/3A TR3 Castle Nut on Right Rear Axle Triumph 3
K TR2/3/3A TR3 4:11 gears in rear Diff Triumph 6
S TR2/3/3A rear brakes tr3 Triumph 1
S TR2/3/3A tr3 rear main Triumph 24
M TR2/3/3A Topping off rear shocks on TR3 Triumph 11
Kleykamp TR2/3/3A TR3 rear fender bolts Triumph 2
RickAnderson TR2/3/3A Wanted: TR3 Rear Bumper Overrider - any condition. Triumph 2
M TR2/3/3A TR3 rear axle hub gasket ???? Triumph 4
S TR2/3/3A rear fender vinyl tr3 Triumph 6
mgedit TR2/3/3A Rear capping 56 TR3 Triumph 4
M TR2/3/3A Topping off rear shocks on TR3 Triumph 13
Kleykamp TR2/3/3A TR3 rear fender needed Triumph 18
K TR2/3/3A TR3 rear overider distance from body? Triumph 3
Tr3aguy TR2/3/3A Rear Lettering TR3 post 60000 Triumph 3
luke44 TR2/3/3A TR3 Rear Bumper Overriders - Upside Down? Triumph 12
T TR2/3/3A The light came on: my TR3 rear apron. Triumph 12
S TR2/3/3A tr3 rear interior panels Triumph 6
J TR2/3/3A TR3 Rear Apron Replacement Triumph 4
K TR2/3/3A TR3 Rear Overider Bracket "distance tube"? Triumph 10
J TR2/3/3A stainless steel rear spring pins for TR3 Triumph 19
O TR2/3/3A TR3 Rear Main Seal Triumph 5
A TR2/3/3A More TR3 Rear main seal problems. Please Help!! Triumph 8
J TR2/3/3A '56 TR3 Brakes and rear axle advice Triumph 7
tinman58 TR2/3/3A Rear main seal TR3 Triumph 11
O TR2/3/3A TR3 Rear Turn lights Versus Rear Stop Tail lights? Triumph 5
S TR2/3/3A tr3 brakes-Rear wheel Triumph 2
