TR2/3/3A TR3 roll bar
tinman58
Hi Guys
I just installed the roll bar (that I hope to never use) and would like your expert thoughts and advice. Something is just not right to me. Color, height or just doesn't work with this car. What do you guys think?
Dan
Could be just the color Tinman but Peter's looks less angular and there's not an angular bit to a TR3....I'd paint it a flat satin black.
Will that fit under a hood?
I doubt you'll worry about the esthetics if you need it though.
Chrome or satin black. Copy the pic into paint and see if you like it.
Paul
Nice TR!
The best thing about my rollbar is the high mounted third brake light. I used to have P/U trucks and SUVs screaming up behind me when I turned into my driveway. Now with the flashing third brake light, they see me much more betterer (I hope they do anyway)
Hi Tinman58, A TR-3 is a hard car to build a roll bar for. Does your car have a flat rear passenger seat area? Those look to be easy to install a rollbar in. My hot rod TR-3 is an early model and I haven't found a roll bar design that looks sturdy enough. I have two concerns, being hit from the side and rolling my car because of the skinny tires. I restored an installed a steel hardtop hoping that with it properly bolted in, it would give me some added protection. Roll bars get scuffed and banged up, and after a couple of years start to look scruffy. A light color scuffs realy stand out, Powder coating is cheap and very durrable, dark colors (black) are less noticable. Good Luck, Bill C. Mesa, Az
A TR3 is s right swine to put alegal roll bar in as they must mount to the frame, not body metal and they must also be full width. That means some fancy bending for the main hoop and some holes in the body for rear braces.
If it is for the street, I suppose anything is better than nothing, but I've seen bars that were very poorly designed.
B TR2/3/3A Street Roll Bar for TR3 Triumph 12
K TR2/3/3A TR3 Timing chain cover scroll seal...... Triumph 5
HerronScott TR4/4A TR3/TR4 tool roll on eBay? Triumph 3
G TR3 roll cage Racing 10
G No directional signals or brake lights on 60 Tr3. Triumph 1
T TR2/3/3A Rear Wheel Bearing instillation on TR3 Triumph 7
RichB4493 TR2/3/3A Rare “TR3” spotted on safari Triumph 3
71TR6 For Sale TR3 Radiator with crank hole- refurbished Triumph Classifieds 3
jfarris For Sale Original Style TR3 Luggage Rack Triumph Classifieds 0
jfarris For Sale TR3 early used fan $25 + shipping Triumph Classifieds 1
71TR6 TR2/3/3A TR3 rear axle shims Triumph 7
IdahoNuke For Sale Free TR3 Seats Triumph Classifieds 0
T Wanted Wanted TR3 rust free nut & bolt restoration Triumph Classifieds 12
R TR2/3/3A 1956 tr3 value? Triumph 7
cguild TR2/3/3A TR3 1991cc engine emits black soot from exhaust Triumph 13
D TR2/3/3A Black TR3 Triumph 20
K TR2/3/3A A TR3 plug check left to right 1234...do I lean out front carb a couple of flats?...turn down correct? Triumph 3
K TR2/3/3A The TR3 is up and running again.... Triumph 7
S TR2/3/3A Battery box for a triumph tr3 Triumph 5
J TR2/3/3A TR3 age Triumph 4
G For Sale TR3 original metal air filters Triumph Classifieds 0
G For Sale 1960 TR3 fitted black cover. Triumph Classifieds 0
S TR2/3/3A tr3 sat all winter Triumph 15
S For Sale FREE - TR3 engine and transmission Triumph Classifieds 5
W TR2/3/3A TR3 Seat Belts Triumph 10
R TR2/3/3A TR3 Timminge Triumph 11
J SOLD!! Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J SOLD!! TR2 TR3 Tie Member Triumph Classifieds 6
S TR2/3/3A tr3 valve spring compressor Triumph 5
