TR2/3/3A TR-3A Headlights Main versess Dip
Arrow
I am re-wiring my TR-3A with a modern after market wiring harness The Triumph Instruction Manual says the blue and red wire goes to the "main" headlight and the blue with white wire goes to the "dip" head light. I would think the "dip" would be the low beam but am not sure and since I am eliminating the bayonet connectors and installing modern plugs I'd rather get it right the first time. Is the main the high beam and the dip the low beam? Thanks Tom
Dale
I'm pretty sure you've got it right. But, then again "dip" may refer to the previous owner, as in the DPO so often referred to here.:smile:
Geo Hahn
Blue/White is the high beam.
If you look at your wiring diagram you'll see that blue/white (UW) is also the wire to the high beam indicator on the speedo.
Banjo
You are correct sir!
Geo Hahn
Arrow said:
...The Triumph Instruction Manual says the blue and red wire goes to the "main" headlight...
Are you refering to the Service Instruction Manual? In my copy, Fig. 34 in the electrical section shows the blue/white wire is for the 'main beam'.
Andrew Mace
Arrow said:
I am re-wiring my TR-3A with a modern after market wiring harness The Triumph Instruction Manual says the blue and red wire goes to the "main" headlight and the blue with white wire goes to the "dip" head light....
I'd love to know what Manual (and what edition) this is, since (as several have pointed out) it is incorrect!
TR3driver
Great Pumpkin - R.I.P
Ditto. Note that there should be several different wiring diagrams, since both the TR3 and TR3A changed several times over the years. If you have a "one size fits all", then there are probably some more mistakes.
A
Arrow
Someone asked which Service Manul I had. I have a really old one I had when I first got this vcar in the 60s bu tthe one I referenced earlier in this string is Service Instruction Manual-Third Edition-Incorporating Supplement for TR3 Model. Issued by Service Divisin, Standard-Triumph Sales LTD. It appears to be a reproduction after market book.
TR3driver
Ok, so where does it say that UR should go to main filaments, rather than UW?
It will also not have the correct wiring for the turn signals, wiper, brake lights and likely dash lamps (depending on your TR3A's commission number). The wiper motor is a particular problem, since if you follow the diagram, it will blow the fuse every time you turn the motor on.
Oh yeah, the instructions for connecting the heater are wrong, too. Connect it to the hot terminal on the fuel gauge (where the diagram shows the wire from the wiper switch).
Roger
Bronze
Don't know why I saw this thread, but if an old Englishman can add his tuppence-worth, it's pretty much an Olde English standard that Blue/White is Main (high) beam, Blue-Red is Dipped (low) beam. Also, "normal" abbreviations on wiring diagrams
are UW and UR, the letter "B" being reserved for Black.
TR3driver
D'oh!
W TR6 Headlights Triumph 6
PAUL161 T-Series MGT 7 inch LED Headlights MG 4
B TR4/4A Headlights Blink Off Triumph 15
7 polishing headlights Restoration & Tools 5
K TR2/3/3A Headlights and their extreme current draw? Triumph 4
K 68 midget. No horn, headlights, turn signals Spridgets 9
Rob Glasgow Halogen Headlights Austin Healey 30
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
rgfrey 1959 Low Beam Headlights Not Working Austin Healey 5
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
B TR6 LED Headlights Thouights? Triumph 26
T Ignition warning light remains on and headlights come on Austin Healey 8
JPSmit Green Mini - with halo headlights Spotted 0
P TR6 New headlights Triumph 24
Martinld123 Just installed LED headlights in BN2 Austin Healey 15
R TR2/3/3A Sealed-beam headlights Triumph 15
R Sealed-beam headlights Austin Healey 13
KVH TR4/4A No Headlights Triumph 4
S TR2/3/3A little caged nut headlights Triumph 2
S LED or Quartz-Iodine headlights for my '67 AH 3000 Austin Healey 22
P Porsche with 5 headlights Other Cars 5
Scotsman TR2/3/3A LED headlights Triumph 4
C TR2/3/3A How to wire headlights for TR3 Triumph 5
AUSMHLY LED headlights Austin Healey 36
rjc157 headlights Austin Healey 12
turbofrog Sprite Control Box - Headlights In-Op Spridgets 4
P Headlights and Turn Signal Light Grounding Spridgets 3
J TR2/3/3A Hooked up the Headlights and let the smoke out!!! Triumph 4
T TR2/3/3A Is there a good way to manage all those wires/connectors for headlights & park lights Triumph 9
T TR2/3/3A TR3 headlights Triumph 12
Parker MGB Headlights won't work after full repaint/restoration... what am I missing? MG 6
D BN2 headlights Austin Healey 3
RickB Lucas Headlights - Just got this from VB Spridgets 8
N Headlights?? Spridgets 8
I Suggestions for bugeye headlights Spridgets 21
F Headlights Stopped Working TVR 2
B Adjust headlights/ "true" them? MG 7
Nelson No more forgotten headlights Spridgets 2
PATR8 Wedge TR 8 headlights problem Triumph 11
AngliaGT New Elise Headlights Anyone? Lotus 2
N Adjusting headlights on a BJ8 Austin Healey 2
H Headlights left ON reminder MG 3
Nelson Aiming headlights Spridgets 1
Trevor Jessie Headlights Spridgets 34
M Headlights and fog driving lights Triumph 44
brgrmyster TR6 Adjusting TR6 Headlights Triumph 8
wkilleffer MGB Adding E-Code headlights to a '74 MGB MG 0
B HID Headlights? Spridgets 4
mountainman TR2/3/3A TR3 Headlights Install? Triumph 6
S Headlights Triumph 32
