Wedge TR 8 headlights problem
PATR8
I have been fighting the lights on my 8 for years now. Initially it was just with them popping up but now one headlight doesn't light and the drivers side side markers have stopped working. I think it may be a grounding issue but I can not find where the headlight loom grounds. Some help?
Mickey Richaud
Don's idea is a good one. (Hey! Even a blind squirrel... :jester: )
But from my poor memory, maybe up where the loom runs above the radiator...? I'm sure someone who knows for sure will be along directly.
tr8todd
Ground wire is a bundle of black wires crimped into a circle connector. The circle connector is ridged to make contact with the body. It is bolted to the body inside the engine compartment just below the cluster of headlamp multiprong connectors. One on each side. Look below the headlamp mounting bolts. Remove the 10mm bolt, clean body and circle connector. Be careful thou. There are two 10mm bolts there. Only remove the one with the ground wires. They serve not only as the grounding spot, but also serve to secure the horns which have captive nuts to receive the bolts. Undo both and the horn will drop out. Then you will need to have a friend hold the horn while you try and fish the bolts back in from above. Clean the multi prong connectors as well. Check for crimped wires up near the moving parts of the headlamp lift mechanism. Check the headlamp switch. There is a white plastic piece in there that wears down over time and fails to apply enough pressure to the contact strips. Follow the electric path till it ends. Sometimes I think a test light and an ohmmeter are a wedges best friend.
GBRandy
I would suggest you pull the switch from the dash and have a look inside it.
If the small metal tabs get bent or corroded, they will cause the issues you are describing. They are pretty easy to clean and tighten once the switch is out of the dash.
On mine the headlights would pop up, but they would not stay lit. wiggle the switch and tada! light...then hit a bump and no light. The side markers are controlled by the center stage of the switch. If that internal tab is not making contact, the side markers will not light.
They come out & apart pretty easy, but as you tug and pull remember you are playing with 30+ year old plastic :smile:
DNK
You mean they're not like a TR6's wiper switch?
PATR8
PATR8
I've cleaned the switch, swapped it out, swapped the relays out, cleaned the grounds, swapped the motors. I am beaten. It has to be the loom
George_H
If the headlight and the side markers that are out are on the same side, I'd bet its a bad connection on the fuse panel... Put the lights on and poke around on the lighting fuses...carefully. The clips that hold the fuses in can be a problem on my tr7s
bighealeysource Problem with headlights on BN6 Austin Healey 3
D TR6 Wiring problem - re headlights/starter motor 74TR6 Triumph 6
W TR6 Headlights Triumph 6
PAUL161 T-Series MGT 7 inch LED Headlights MG 4
B TR4/4A Headlights Blink Off Triumph 15
7 polishing headlights Restoration & Tools 5
K TR2/3/3A Headlights and their extreme current draw? Triumph 4
K 68 midget. No horn, headlights, turn signals Spridgets 9
Rob Glasgow Halogen Headlights Austin Healey 30
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
rgfrey 1959 Low Beam Headlights Not Working Austin Healey 5
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
B TR6 LED Headlights Thouights? Triumph 28
T Ignition warning light remains on and headlights come on Austin Healey 8
JPSmit Green Mini - with halo headlights Spotted 0
P TR6 New headlights Triumph 24
Martinld123 Just installed LED headlights in BN2 Austin Healey 15
R TR2/3/3A Sealed-beam headlights Triumph 15
R Sealed-beam headlights Austin Healey 13
KVH TR4/4A No Headlights Triumph 4
S TR2/3/3A little caged nut headlights Triumph 2
S LED or Quartz-Iodine headlights for my '67 AH 3000 Austin Healey 22
P Porsche with 5 headlights Other Cars 5
Scotsman TR2/3/3A LED headlights Triumph 4
C TR2/3/3A How to wire headlights for TR3 Triumph 5
AUSMHLY LED headlights Austin Healey 36
rjc157 headlights Austin Healey 12
turbofrog Sprite Control Box - Headlights In-Op Spridgets 4
P Headlights and Turn Signal Light Grounding Spridgets 3
J TR2/3/3A Hooked up the Headlights and let the smoke out!!! Triumph 4
T TR2/3/3A Is there a good way to manage all those wires/connectors for headlights & park lights Triumph 9
T TR2/3/3A TR3 headlights Triumph 12
Parker MGB Headlights won't work after full repaint/restoration... what am I missing? MG 6
D BN2 headlights Austin Healey 3
RickB Lucas Headlights - Just got this from VB Spridgets 8
N Headlights?? Spridgets 8
I Suggestions for bugeye headlights Spridgets 21
F Headlights Stopped Working TVR 2
B Adjust headlights/ "true" them? MG 7
A TR2/3/3A TR-3A Headlights Main versess Dip Triumph 10
Nelson No more forgotten headlights Spridgets 2
AngliaGT New Elise Headlights Anyone? Lotus 2
N Adjusting headlights on a BJ8 Austin Healey 2
H Headlights left ON reminder MG 3
Nelson Aiming headlights Spridgets 1
Trevor Jessie Headlights Spridgets 34
M Headlights and fog driving lights Triumph 44
brgrmyster TR6 Adjusting TR6 Headlights Triumph 8
wkilleffer MGB Adding E-Code headlights to a '74 MGB MG 0
B HID Headlights? Spridgets 4
