TR2/3/3A The steel head stud washers?
karls59tr
Bronze
I installed the head gasket today. i was missing a couple of steel flat washers so I installed these and torqued the head down. They are made of yellow zink but are the same thickness as the missing ones. How much of a mistake is this and is it going to come back and bite me on the ass?:unsure:
CJD
For head bolts or other important fasteners I request "hardened and ground" The hardening ensures they are as hard as your bolts and will not compress over time, and the ground ensures they are absolutely flat, so they carry the bolt load evenly to the head surface. If you already used those washers, then I would not go to the trouble to change them out...just be sure to check the torque a couple times to ensure they are holding tension. A softer washer is still better than none at all.
Sarastro
In my experience, grade 8 hardware is usually zinc chromated, and lesser hardware is not. So, the washers you used are likely grade 8 anyway.
K
karls59tr
Bronze
Just saw this post after responding to your first post. So this washer should be OK in your opinion?
Bristol401
Most bolts, nuts and washers are Zinc coated, no matter what grade they are. Yes, Grade 8 does often have that yellow color, but anyone can buy a zinc chromate kit on the internet. That color does not indicate any specific alloy. Check ARP for quality grade 8 hardware.
Sarastro
I'm quite aware of this. I do zinc plating (plus other metals) and chromate conversion. I don't use a kit; I use electrochemistry.
T head gaskets?-copper of steel? Triumph 4
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
S TR2/3/3A brass fitting from a steel brake line Triumph 2
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
Guido36 Stainless Steel Bumpers Austin Healey 5
B Stainless Steel Exhaust System Wanted Austin Healey 5
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
S TR2/3/3A steel bushings for the lower Arms Triumph 10
Popeye TR4/4A Crankshaft pulley recommendations: One piece alloy, two-piece steel, wide, narrow...? Triumph 12
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
D Removing the last rust from pitted steel Restoration & Tools 11
B Electrochemical cleaning of stainless steel welds Restoration & Tools 7
Joel Lester Wanted Wanted - TR6 steel wheels Triumph Classifieds 6
DocDup1 General TR TR6/TR250 Steel Wheels Triumph 3
DocDup1 For Sale TR250/TR6 Steel Wheels Triumph Classifieds 5
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
T Trying to identify a steel plate part Austin Healey 2
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
L For Sale 1960 Austin Healey steel oem wheels Austin Healey Classifieds 0
B TR2/3/3A Tubes in steel wheels? Triumph 18
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
J TR2/3/3A Figure of Eight Gasket Compression - Copper vs. Steel Triumph 18
G For Sale Stainless Steel TR6 Bumpers Triumph Classifieds 0
I Stainless steel exhaust. Austin Healey 5
K TR2/3/3A Pressed steel body plates?????? Triumph 7
M TR2/3/3A Fitting Modern Steel Wheels Triumph 4
D TR2/3/3A TR3 Steel Wheels Triumph 7
busybrit TR4/4A Steel dashboard color Triumph 1
JimLaney How to treat media blasted steel Spridgets 3
B ISO two[2] steel road wheels, Morgan Other British Cars 0
KVH General Tech Steel Wool on Rod Bearings Triumph 9
T TR2/3/3A TR3 steel wheels Triumph 6
Gerry M TR6 TR6 Steel Wheel Question Triumph 3
simon1966 The jigsaw puzzle in Aluminium and Steel Commences. Austin Healey 7
busybrit TR4/4A TR4 Steel dashboard color Triumph 8
D TR2/3/3A Tubes in steel wheels? Triumph 15
DornTRoriginal TR2/3/3A Stainless Steel Exhaust Installation Triumph 4
J TR2/3/3A TR-3 Steel Wheel Repair Triumph 3
M Front steel brake lines Spridgets 9
BillyB62 TR2/3/3A Factory steel hardtop Triumph 14
AHS 1968 steel dashboard - can anyone confirm? Spridgets 3
KVH TR4/4A Shortening the Steel Wrapped Heater Control Cables Triumph 2
J General Tech Stainless-steel caliper pistons Triumph 8
P Steel Wheels for a BJ8 Austin Healey 14
Rob Glasgow Tourist Torphy Stainless Steel Exhaust Systems Austin Healey 27
Jeepster Mixing stainless and mild steel exhaust Austin Healey 5
T TR4/4A Converting TR4a from wire to TR6 steel wheels Triumph 7
TulsaFred Polished stainless steel bumpers? Spridgets 13
