Steel Wheels for a BJ8
peteatgr
Thinking of changing my original 60 spoke wire wheels for steel wheels. Considering taking an extended trip in the car and don't want to have to shimmy my way across country on out of round wire wheels. Is there a good source for steel rims that fit properly on a BJ8 phase II, can fit a reasonable size tire and can still accept Healey hub caps?
maxwedge5281
i dont believe that you can run bolt on wheels without changing out the front hubs and using different brake drums on the rear. you might be able to use your current rear brake drums with a spacer. probably be easier to buy a set of reproduction minilite type spline drive wheels.....sorta expensive for a trip unless you plan to keep them. i just changed my bj7 over to minilite bolt on wheels and i am very pleased with the ride and driveability. my understanding is that the bolt on front hubs for a bj8 are rare and expensive. someone on the forum had a set for a bj8 several months ago.there are others on this forum that are more familiar with other possible choices.
Csarneson
I second the mini-lite option. Converting your car to steel wheels will be an expensive endeavor that hurts the value of your car. Adding mini-lites is probably about the same cost and add value while looking good as well.
P
peteatgr
Thanks. I was actually thinking of the steel wheels as a possibly less expensive, single trip, option with the wires going back on after. The extra expense, and advice, will make me look again at the condition of the wire wheels and at the mini-lite options.
Coastalman
Have Allen Hendrix true and check your wire wheels. He is right up the road in Greensboro. Once the wheels are trued you can really enjoy the ride. I know he did Steve Byer's wheels and Steve has driven his car across the country and many other long trips with a smooth ride. Allen did my wheels and I had not problem with shimmy or shake at speeds up to 85 mph. (My top end, not my car's)
Charlie
Keoke
I agree with the above, and be sure you have the neccessary bits to make puncture repairs on the road because you may find no one elese does.
P
peteatgr
Thanks. I spoke to Allen this afternoon. He'll probably get some wheels to true quite soon. He also mentioned rear brake drums almost never being true. I hadn't heard that. Anyone have that situation, and did fixing that problem relate to curing/reducing the shimmy between 60-65 mph?
Patrick67BJ8
I had Allen do my brake drums and a new set of wheels as well as tires and I have zero scuttle shake. I'm sure that my Jule Frame contributes to the smooth ride too but I think it also is the reason my Healey has a very "solid" ride and handling feel to it.
BoyRacer
You need different front hubs to use bolt-on wheels. These hubs.... for a BJ8.... are extremely rare - almost unobtainium. Healey racers covet these hubs. However, if there is a racer out there and seeing this post, I have a set of these hubs for sale. Send me a private message.
maxwedge5281
bob, that is a good question. i changed my bj7 over to boltons from spline drive minielite type wheels just because that is what i preferred. i just drive my car on the street but it does feel more planted and balanced with the boltons. no one locally wanted to balance the spline drive wheels. not that that was a major factor. i believe that the boltons are much lighter than the spline drives but that is just my opinion. and, to me the boltons are much neater in appearance with no knockoffs. i wish i could find a very small center cap that fits the wheel center without protruding like the minilite center cap. and thanks to boy racer and randy forbes for selling me the necessary parts for my conversion. my bj7 does have a 383 sbc roller motor so boltons just seemed to be the way to go for me.
Patrick67BJ8
Charlie
A few years ago Allen Hendrix told me that it's cheaper to buy a new wire wheel for a Healey than to true an old one.
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
Joel Lester Wanted Wanted - TR6 steel wheels Triumph Classifieds 6
DocDup1 General TR TR6/TR250 Steel Wheels Triumph 3
DocDup1 For Sale TR250/TR6 Steel Wheels Triumph Classifieds 5
L For Sale 1960 Austin Healey steel oem wheels Austin Healey Classifieds 0
B TR2/3/3A Tubes in steel wheels? Triumph 18
M TR2/3/3A Fitting Modern Steel Wheels Triumph 4
D TR2/3/3A TR3 Steel Wheels Triumph 7
B ISO two[2] steel road wheels, Morgan Other British Cars 0
T TR2/3/3A TR3 steel wheels Triumph 6
D TR2/3/3A Tubes in steel wheels? Triumph 15
T TR4/4A Converting TR4a from wire to TR6 steel wheels Triumph 7
maxwedge5281 wtb front drums for steel wheels Austin Healey 1
maxwedge5281 wire wheels to steel wheels...bn6 Austin Healey 0
maxwedge5281 front disc brake hubs for steel wheels Austin Healey 24
R Original Steel Wheels Triumph 12
Scotsman TR2/3/3A Should inner tubes be used with TR3 OEM steel wheels Triumph 3
angelfj1 Alloy wheels for that authentic steel wheel look. Triumph 11
Rut Bugeye steel wheels [original] needed Spridgets 15
T T-Series Need Advice - MGTF Steel Wheels Need Attention MG 2
T Steel wheels and tubes Triumph 12
jjbunn Wire wheels vs. steel - pros/cons? Jaguar 15
philman Wedge steel wheels for wedges, spits, etc Triumph 3
Randy Forbes Original steel disc wheels... Austin Healey 0
G T-Series MGTD Steel wheels MG 3
eschneider do they exist --- splined steel wheels [not wires] Other British Cars 15
K TR2/3/3A What is a set of good used TR3 steel wheels worth? Triumph 18
G Trouble balancing steel wheels on '79 Spridgets 2
Tinkerman Steel Wheels vs Wire Wheels Triumph 17
T TR2/3/3A TR3 steel wheels - always silver? Triumph 2
abarth69 Steel wheels and paint Restoration & Tools 10
58Custom What parts to go from wire to steel wheels? Spridgets 15
rulle7 Clear coat steel wheels...? Spridgets 6
T stock earlier style steel wheels MG 11
S 6JX15 original steel wheels? Do they exist? Triumph 5
T TR2/3/3A Tr3 steel wheels Triumph 12
K TR2/3/3A The steel head stud washers? Triumph 7
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
S TR2/3/3A brass fitting from a steel brake line Triumph 2
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
Guido36 Stainless Steel Bumpers Austin Healey 5
B Stainless Steel Exhaust System Wanted Austin Healey 5
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
S TR2/3/3A steel bushings for the lower Arms Triumph 10
Popeye TR4/4A Crankshaft pulley recommendations: One piece alloy, two-piece steel, wide, narrow...? Triumph 12
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
D Removing the last rust from pitted steel Restoration & Tools 11
B Electrochemical cleaning of stainless steel welds Restoration & Tools 7
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
