Jim_Gruber
Every time I start Bugsy, ease off choke after less than 1/2 mile in the summer, I catch a whiff of raw gas. Cannot find a leak anywhere and suspect might be gas escaping from the overflow on the carbs. Too small an amount to see if I stop the car and pop the bonnet but the smell of raw gas is there for a moment and goes away. It will come back occasionally after a hard pull but much lighter smell not nearly as intense.
Situation 2, stopped at Subway to grab something to eat and came out 5 minutes later. Car was slightly warmed up but only 2-3 miles from home, 80 degree temps. Turned the key and a tremendous kaboom from the muffler. Last night turned key cold after sitting 3 days, another small kaboom not normal starting sounds.
Can I raise the question that I might have a leaky float valve. Now adjustable floats were shimmed properly by my LBC Mechanic last summer so I don't think floats are set too high but perhaps the valves themselves are leaking and not shutting off tightly hence small of gas but I cannot see evidence of gas under the bonnet. Also could account for backfire/kaboom if gas was leaking into the cylinders from a leaky flat valve could it not.
I have a spare set of SU's, may simply change out the top of the carbs and change floats to one with an adjustable type to see if gas small goes away. Thoughts anyone?
Leaking float valve, time to change the oil as well if that is the case.
