Forgot Positioning of Lids on Carb Float Chambers
hundredsixinsf
I removed the tops of the float chambers on the carburetors in my '59 100-6 and forgot what position the threaded inlets on the lids should be in. Are they oriented closer to the middle of the engine compartment or closer to the driver side fender? I know that while standing on the driver side of the car, the inlet for the front carb points to the front of the car and the inlet for the rear carb points to the rear of the car. Just need to know which way to rotate the lids. Thanks!
Hi 100-6, I think they are positioned so the overflows point outboard.---Fwiw-Keoke-?
Closest to the motor, you can kinda see it from this shot.
Basil General MG I forgot I had this on my server MG 8
jlaird I use to know the answer but forgot. Spridgets 1
TR6BobNF Lotus - Forgot Something Spotted 4
TR6oldtimer The thing I forgot to do Triumph 2
M Forgot to save link Triumph 5
T Forgot to check under the bonnet... Triumph 16
T Drove by a car that I forgot I owned. Triumph 6
aeronca65t Forgot these... Racing 10
PATR8 Wedge TR7 DPO forgot the mention a few things Triumph 9
jlaird Forgot Spridgets 6
longbridgehealey oops - forgot to attach e-bay listing Austin Healey 2
G Setting valves with GP2 cam.....forgot the number Triumph 2
jlaird Forgot to say Spridgets 1
jlaird Question, I forgot Spridgets 10
jlaird I forgot to say Spridgets 7
jlaird Oh forgot to mention Spridgets 2
B TR2/3/3A Positioning new cam sprocket Triumph 4
B TR2/3/3A Positioning of exhaust bracket Triumph 7
TulsaFred Timing Gear positioning on 1275 Spridgets 7
K BT7 Fuel Line Positioning Austin Healey 12
germanmichel Distance hardtop/ top positioning guiding sleeves Austin Healey 12
Andrew Mace TR2/3/3A TR3A speedo and tach positioning Triumph 11
HealeyPassion Dead pedal and pedal positioning project paper Austin Healey 3
E Positioning Electric Fan Triumph 13
Tronch Coil positioning with alternator Austin Healey 2
tony barnhill Seat Positioning Racing 8
Mark_Gibson Sling Positioning for TR-2 Motor/Tranny Removal Triumph 8
W Glass Washer Bottle Lids Austin Healey 0
B those darn trunk lids!!! Spridgets 11
