SherpaPilot
Another Stromberg question again: OK, I know there has been a ton of material generated on these carburetors but I can't seem to find the answer to my question. I have recently downloaded the buckeye technical information and plan on going through each detail within the next few days. Although my TR6 runs very well, my question concerns the piston lift method of determining rich vs lean settings. With the engine properly warmed, I have attempted to determine if my carbs are running too lean or too rich by performing the piston lift method as described in my Bentley manual as well as other manuals and videos. According to this information as the piston is lifted approximately 1/4 inch, the rpm will either increase (indicating too rich) or decrease and shut-down (indicating too lean). In my case, these carbs always decrease and want to quit when the piston is lifted. I have adjusted each needle valve IAW the manual (turning it clockwise) to enrich the mixture. At full adjustment travel clockwise, there is no effect on the carbs and they continue to decrease RPM and will shut try to shut the engine down. Tonight I tested the car with both carburetors enriched as much as the adjustment would handle (to the full stop) and the car ran well as usual. I pulled the plugs and found normal conditions with a slight amount of carbon buildup at the base and within the threaded portion. I'm starting to think there is something such as an "o" ring that has failed in both carburetors causing this lean evidence. A part of me wants to leave well enough alone and continue to take plug readings but another voice is telling me there is something that is not correct and I had better fix it before I end up doing damage.
This is a freshly rebuilt cylinder head with new exhaust valves. All valves have been adjusted and checked. The ignition system is properly tuned and fresh including wires, plugs and timing. The fuel is fresh with the highest octane I could find in my area (91). The mechanical fuel pump is somewhat new and is working as advertised. The fuel filter is new. There is no problem with fuel flow. What point am I missing?
