Steering Wheel Removal
mxp01
Gentlemen:
I know this ground has been covered in the past, however:
Can someone provide advice for removing the steering wheel from a 1972 Midget? I have the nut loosened, but now the wheel is stuck hard on the steering column.
Thanks,
Mike Pennell
A wheel puller is the easy way. Borrow one from Checker or Autozone or go to Harbor Fright and buy one. The flat style with screws, not the hook style
And mind your teeth. When it lets go it will let go with authority. You might try pounding in first. Also be careful with the nut and cross threading on those fragile threads on the steering column. Use only the soft, nuts from VB or MOSS if you need to replace. Don't ask me how I know.
BTW-Sears Hardware sells a thread file if you need to straighten things up.
I made a puller by taking a flat plate and using the little bolt holder thin plate thing as a guide and drilled holes in the plate. Then I used some bolts going through the plate and pushed against the splined stem with it using the 6 bolts.
No matter how bad it gets, Don't try to knock the steering column out the back with anything...the threads will mangle! Don't ask.
Cheers
Cheers
You mean don't do what John Twist did in the video? Running the nut out to flush was an important step I think he said.
The metal on the shaft is super soft and threads are real fine. John Twist definitely knows what he is doing. Pressure on the wheel is very important in making this work. Also making sure when rethreading the nut that it goes on straight.
I got in a hurry once and ran the nut all the way out to where it was flush with the end of the shaft so I could "tap" it with a hammer and hopefully knock it out the back of the steering wheel. Well, as Jim mentioned, the metal was so soft that it just crushed the threads immediatly. Then it took me forever to find a machinist with a lathe that would turn those threads for me; No one wanted to do anything that was automotive related for some reason (I thought metal was metal and money was money, but apparently not the case in the Sacramento area). Just a word of warning to prevent someone from going through that experience! everyone else has brought up good suggestions for getting the wheel off.
Mark
S TR2/3/3A Steering wheel removal. Triumph 4
R TR2/3/3A Steering wheel hub removal Triumph 11
Walter74 Adjustable steering wheel removal Austin Healey 4
AUSMHLY Adjustable steering wheel removal Austin Healey 5
L T-Series 1952 TD Steering wheel removal MG 8
H Steering Wheel Removal after being attached for 58 years. Nothing is easy. Spridgets 6
AN5Sprite steering wheel removal Spridgets 3
1 Steering Wheel Removal Austin Healey 7
boxfullofyertoys Steering wheel removal issues Spridgets 11
doates Need Steering Wheel Removal Help Triumph 20
Newkie Steering wheel removal MG 11
ModifiedBJ7 Steering Wheel Hub Removal Austin Healey 5
BOBBYR steering wheel removal Austin Healey 7
G BFH method of steering wheel removal MG 4
jjbunn Steering Wheel and Hub Removal MG 43
B Non-adjustable steering wheel removal/adjustment Austin Healey 1
drooartz Bugeye steering wheel removal Spridgets 17
7 Steering Wheel Removal Austin Healey 5
WidespreadPanic TR6 TR6 Steering Wheel Removal Success Latest w/pic Triumph 26
W BE Steering Wheel Removal Spridgets 6
P Non adjustable steering wheel removal Austin Healey 7
zimmy steering wheel removal Spridgets 3
S Steering Wheel Removal MG 19
Stewart Steering Wheel removal MG 10
B Steering Wheel Removal MG 14
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
K 1968 Midget Steering wheel Spridgets 1
Editor_Reid Wrapped Steering Wheel Austin Healey 9
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
kodpkd Leather Steering Wheel Cover Austin Healey 3
S Steering Wheel Brand Austin Healey 5
B TR4/4A What is this Steering Wheel Center? Triumph 6
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
Celtic 77 MGB Steering wheel fitment MG 11
LAW75 Derrington Steering Wheel Austin Healey 19
waltesefalcon New steering wheel Other Cars 2
R TR2/3/3A Steering Wheel hitting my belly Triumph 22
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
A Austin A40 trafficator steering wheel Other British Cars 5
T Steering Wheel Adjustment Range Austin Healey 0
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
J Wanted Adjustable steering wheel circlip Triumph Classifieds 4
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Cappy Moto-Lita Steering Wheel Installation Austin Healey 3
K TR2/3/3A Steering Wheel hold down Nut Triumph 6
J Steering Wheel Repair Austin Healey 32
