On my 1979 MGB, the turn signal / dimmer switch seems to be bad as now it has no spring back and will light the bright lights unless I manually push it back towards the dash. I have removed the plastic housing around the steering column but it appears that you have to remove the steering wheel in order to remove the switch.
I removed the nut and then put it back on so that I could use it to absorb a few blows to the shaft but I have only got the wheel about halfway off. I do not want to damage the threads so I was wondering how to get the wheel off. I tried some WD-40 but it really didn’t help. It does not look like a steering wheel puller would work but I don’t know.
Any suggestions? I tried a search in the forum but found no real information.
Thanks,
Scot Stern
Thanks,
Scot Stern
