Slowly getting there,cockpit painting nearly done
TR6oldtimer
Was this a pain to prep and paint. I am sure glad it is almost done. Just one more coat of red to go.
Click to enlarge
Re: Slowly getting there,cockpit painting nearly d
Ray, what's the seam filler for?
Paint alone will not seal a seam, so to keep moisture out and help prevent rust, I used a seam sealer. The seams on the car were originally sealed with a tar based sealer.
The seam sealers I am using do not recommend application over bare metal, so under the dash I cut in the seams with a paint brush, then applied the sealer. I did not do this on the floor and rear deck (but could have). The first coat of red went down, then I sealed the floor and rear deck and will give the whole cockpit a second coat and it is done.
Call the Cops, Ray!!!!
Yer tranny's been stole............. :lol:
Nice clean job. Great work!
Excellent job! It's the attention to detail and completing the job that makes the difference.
Looks good, Ray. Have you considered putting anything <span style="text-decoration: underline">inside</span> your rockers? I actually opened up both ends of my rockers with a 1 1/2" hole saw and coated the insides with rust encapsulator paint, then plugged the holes with giant rubber grommets and sealed them in with undercoating.
Always nice to seen underneath a dash board and be able to really paint this area. Sometimes I wish I had done a body-off resto. Sometimes.
Interesting. New floorboards don't come with jack holes anymore. My Heritage floors did, but I make plates and welded them over. Like I need another hole......
Bill, My new floor panels came with jack holes, and I too welded them closed. On the passenger side, the wife's high heels (yes some woman still wear them) would always punch out the plug.
As to coating the inside of the rockers, I had to replace them so all is well.
And you did not miss anything by not doing an off frame restore. If it were not for the floors and rockers I would not have done it.
Ray
Looks great. Nice clean job. :thumbsup: :thumbsup:
So when can you come over and paint my '59? Its all blasted and ready for you :smile:
TulsaFred Rebuilt 1275 slowly getting dialed in Spridgets 14
D Slowly getting irritated British Motor Corp 13
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
S Some observations/results to slowly diagnose why my Healey overheats at idle Austin Healey 40
longbridgehealey BN4 turn indicator blinking very slowly Austin Healey 2
PAUL161 T-Series TF is slowly coming together MG 90
PatGalvin It's gettin' done, slowly... Triumph 72
Randy Forbes Things are slowly shaping up... Austin Healey 10
V Disc Brakes Releasing Slowly Austin Healey 6
PAUL161 Restoration Slowly Begins MG 16
DNK Slowly, But Surely, and don't call me Shirley Triumph 12
tony barnhill Slowly Becoming Red... Spridgets 12
Brosky Frame project slowly moves ahead Triumph 29
Brosky Frame restoration slowly begining in RI Triumph 26
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Celtic 77 MGB Getting closer! MG 5
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
D TR2/3/3A Getting difficult to start. Triumph 6
S TR2/3/3A problems getting the engine to run correct Triumph 21
J MGB 73 getting loud squeal with acceleration MG 11
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
M Getting behind the dash on BJ8 Austin Healey 4
John Turney Getting Speedometer out of the Case Austin Healey 6
tr6nitjulius General TR Part 4 What We Missin' we getting closer Triumph 0
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
Rob Glasgow Getting Ready for Winter Austin Healey 24
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
J TR2/3/3A Finally getting started Triumph 20
glemon GT6 GT6 Getting Some Recognition Triumph 8
K TR2/3/3A Dismantling Speedometer...getting the odometer pin past the case??? Triumph 2
D Getting closer... Spridgets 2
RAC68 3D Printing Getting Closer Austin Healey 16
bighealeysource Getting rid of pesky rubbing/polishing compound overspray Austin Healey 5
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
steveg Really Getting Into one's Healey Austin Healey 17
M TR5/TR250 problem getting engine running Triumph 15
simon1966 Seats upholstered and the shrouds getting cracks fixed Austin Healey 9
Jim_Gruber Brake Light - Getting them working Spridgets 8
Darrell_Walker General TR TR3A on Comedians in Cars Getting Coffee Triumph 7
S TR2/3/3A getting a new multi meter Triumph 9
gbtr6 TR6 Getting frustrated getting my TR to run properly Triumph 17
RickB MGB Rain water getting inside behind dash MG 17
drambuie Getting more horse power from a Healey 100 Austin Healey 63
J TR2/3/3A Joe the TR3 Guy getting started with suspension Triumph 4
Jim_Gruber 1/4 Elliptics- Getting the Bast__rd Apart Spridgets 22
steveg HD8s - getting below 1000 rpm idle Austin Healey 4
steveg Unable to edit posts, getting a wierd message FORUM Navigation Questions 2
