    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
T-Series TF is slowly coming together
PAUL161
A lot of work, but is starting to pay off. Had to replace some wood, did a lot of work on the rear quarters after removing them, including removing a lot of Bondo on the right rear quarter. I hate Bondo! Then leaded in some slight deformities. I couldn't believe that I remembered how to lead, but it came back in a short time. Put everything back together and re aligned everything and all fit perfect. Temporarily mounted the windscreen bracket before sending out for re chroming, just in case the holes had to be aligned, as I cut the scuttle weld on the left side to re position it where it should have been in the first place. It came out perfect! Here's a couple shots of the tub without the firewall in place, which is at the media blasters along with the fenders and some other bits. They won't be ready until the following week, so I'm at a slow down point. Get the firewall back and bolted up I can get the tub back on the chassis to align the doors. One of the worst things to do on these cars. Here's some pics. PJ
Some new wood,
Windscreen brackets for temp fit,
New leaded area replacing Bondo,
That metal work is beautifully done sir.:applause: Recently my curiosity with the T-Series has been been growing. For me at least you will not be able to over post. Keep the info and pictures coming!:encouragement:
Very nice work! That will be a fine looking car when you're done.
Keep the photos coming, enjoying going along for the ride with you.
Thanks guys, Seems like I've been working on this thing forever. Reminds me so much of the 1930s American cars I've done over the years with the wooden frame bodies. So wood framing isn't a stranger to me and that helps on these T series cars. I'm beginning to see a very faint light at the end of the tunnel, very faint! :highly_amused: PJ
Funny tou should say that - I was just thinking that it looks like a whole different craft with that wood. But, what a great standard of work!
Thanks JP, long ways to go yet. The folks I chose to do the blasting in Tulsa, specialize in antique and custom cars. They are so busy I won't get my stuff back for another week and a couple of those pieces are holding me up. Their popular around here, reason their in such demand. PJ
Will, I advise anyone who is more interested in owning and driving a T series car, is to buy a driver, one that can be put on the road with little or no repairs. That way you can have the best of both worlds. You have something to drive and can work on it at your leisure. I've been working on this car for 4 years and have at least another year to go, if I'm lucky. It was drivable when I bought it, but wanted it for a full restoration, which meant a complete tear down. Cost wise for a complete restoration, I won't even get into that, as the cost of parts for the T series are out of sight! Just a friendly bit of info. PJ
[SIZE=-1]Right Door,
Here's the right door and you can see the holes at the top. The holes being drilled by a PO for a tonneau cover. This door is going to take some time to get it perfect. Even though I believe this door was a replacement years ago, it's in sad shape. I ran out of lead, which the two arrow areas has to be leaded in and I'll lead the holes in at the same time. Cant buy the good lead anymore, so I have to go to a junk yard and tell them I need lead to make some fishing sinkers! That way they'll sell it to me. Crazy huh! Only good thing about the doors is, the left door is near perfect! PJ[/SIZE]
Can't get good lead? What is being sold these days for lead body filler? Something other than lead, I guess.
I think it's funny that lead for fishing weights is OK, but you can't have it for automotive body work.
Im learning that a T- Series is a far off adventure best saved until Im more com$ortable in life. Though what a gorgeous car.
We purged a lead supply about a decade ago that would have kept us in "high cotton" for years! Really sorry, Paul! I'd have sent you some for the shipping.
...now I feel like a tur*....
:frown:
Paul,
I've purchased lead from these guys for other projects. They use USPS flat rate boxes for shipping so shipping costs are good.
https://www.rotometals.com/Lead-Products-s/20.htm
Most of the lead around here has been hoarded by the chronically paranoid.
Chronically paranoid! I know what you mean. If you touch it, you'll fingers will eventually fall off, lead sinkers will effect the fish and make them un eatable! Plus a thousand other reasons why it should not be allowed! Everything has bad points if treated wrong. I don't want to eat it, just fill in a couple dents. Eastwood sells it, but theirs has 30% tin in it and I don't like it for body work but good for putting radiators back together. Thanks for the tip, much appreciated.
Don't feel bad Doc! I've gave the stuff to the junk man before just to get rid of it, as I knew I was done with fixing up junkers! What a joke that was. :highly_amused: I'm still beating on panels, ----- when I could be fishing, or hunting, or camping, or ----- something a little less insane! Well, summer's almost here and I have pastures to mow and fences to fix, plus numerous other farm things, so a slow down on this antique piece of British culture is in the works. PJ
Sleeping on the ground? In the rain? Is not "less insane" than LBC's :grin:
JP, When camping and I use that term loosely, we have 8 wheels under us! :highly_amused: PJ
Had to replace the battery box with a new one. Had to buy a spot welder to do the job. All came out pretty nice. Impressed. :encouragement: PJ
Nice work, and you managed to work in a new tool purchase too. Nothing wrong with that.
Yeah I know about the new tool purchase LOL! I wouldn't have bought it if someone around here had one I could use, seeing how it'll be on the shelf more than on the bench! :rolleyes2: PJ
Lookin sweet. Need...more... tools... I have so very few.
Finally got the tub back on the chassis for fitting the doors and other bits. Tried to fit the new side panels and ran into issues. They are too long for one, which I have been informed that this is normal and they have to be cut! The front part is too high and the bottom has to be cut off about 1 inch. Problem with that is, it has a rolled edge! The little step on the bottom behind the shock was bent in the wrong position and has to be cut off and welded aprox 1/4 inch higher. Some holes are missing and have to be located and drilled. All of this sounds pretty normal for some of the sheet metal we get, but for what these cost, there's no reason for any bends to be in the wrong position! Three bolts are holding it now and their positions can't be changed, so a lot of figuring has to be done! There 400 bucks a side and I bought two. My main complaint is, there's no indication that any modifications had to be made to make them fit! A lack of communication is the problem. If I knew that, I would have restored my original panels and saved a bunch of money. Here's some photos of the right panel, the left is still in the box. Now I have to spend hours making them right! I'm not happy about that. Thank goodness I didn't put the new grill on before starting this maneuver! PJ
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
S Some observations/results to slowly diagnose why my Healey overheats at idle Austin Healey 40
longbridgehealey BN4 turn indicator blinking very slowly Austin Healey 2
PatGalvin It's gettin' done, slowly... Triumph 72
Randy Forbes Things are slowly shaping up... Austin Healey 10
TulsaFred Rebuilt 1275 slowly getting dialed in Spridgets 14
V Disc Brakes Releasing Slowly Austin Healey 6
PAUL161 Restoration Slowly Begins MG 16
D Slowly getting irritated British Motor Corp 13
DNK Slowly, But Surely, and don't call me Shirley Triumph 12
TR6oldtimer Slowly getting there,cockpit painting nearly done Triumph 11
tony barnhill Slowly Becoming Red... Spridgets 12
Brosky Frame project slowly moves ahead Triumph 29
Brosky Frame restoration slowly begining in RI Triumph 26
Carlbanan56 MGB Stud coming lose MG 7
AngliaGT MGA Barney Gaylord Coming to Roanoke MG 0
sparkydave Zenith auto choke coming loose Spridgets 2
S TR2/3/3A Smoke coming out of crankcase vent? Triumph 21
sparkydave Zenith auto choke coming loose Spridgets 3
Trevor Jessie Any of you Spridget guys coming to MG2016 in June? Spridgets 3
7 brake warning light coming on Other Cars 5
T TR4/4A Tips on controlling heat coming up through shifter opening? Triumph 14
jaegzie Maiden voyage coming up tomorrow for my bugeye. Spridgets 16
P TR6 tr6 coming on market Triumph 2
Martinld123 Water Coming Out of Exhaust at Start-up Austin Healey 7
Lukens TR2/3/3A The hits just keep coming Triumph 2
JPSmit Ms Triss is coming home today Spridgets 7
JPSmit MG 2015 - anyone going [or coming] repost from MG board Spridgets 1
Got_All_4 TR2/3/3A Paint code / formula coming to a head Triumph 28
B no fire coming out of coil Sunbeam (Rootes) 4
Geo Hahn TR4/4A Stumble Coming Off idle Triumph 9
Sarastro T-Series Coming down the home stretch... MG 19
DNK TR4/4A Irene's car coming to America ;] Triumph 5
MY66AH Coming to a Snap On Calendar near you. Spridgets 9
toysrrus TR2/3/3A Coming back soon. Triumph 8
dougie US Championship Winning Healey Coming to Auction Austin Healey 5
H Another big Healey coming my way? Austin Healey 3
Superwrench My BT-7 coming back to life ! Austin Healey 12
Mickey Richaud MGB New MGB Book Coming MG 3
duffy THE OLYMPICS ARE COMING Other British Cars 1
Pythias Portland Autojumble Coming Up. Spridgets 8
J Spitfire New Spitfire based Kit Car coming Triumph 28
Johnny Austin Healey in a new movie coming out... Austin Healey 0
longbridgehealey interior is coming along Spridgets 31
CZ_Dave They are coming out of the woodwork! MG 6
DrEntropy Just learned FIAT is coming! Other Cars 28
T SoCal TT coming up - who is in? Triumph 10
hooey summer coming Spridgets 1
T TR4/4A Randy - how is your TR4 engine build coming along? Triumph 18
W Goldie coming up for auction Austin Healey 15
