Rover 3.5 Engine Numbers
SanDiegoDude
Hello folks: OK I have a 75 RHD STAG with a Rover 3.5L replacing the Triumph "you know what". The engine transplant was done by Peak Performance (Heathrow) UK, not in biz now. It has to be an older V-8 but I cannot find the where the Engine numbers are located...not on the "even # cylinder bank" so then where? I'm doing the last bits on ignition... engines turns with compression but won't fire off..more useless questions later.
Regards
Harve in San Diego
2000 VDP
76 Midge
75 Stag
tr8todd
On the drivers side, below the heads, between the two middle lowest head bolts, there will be a flat area with the number and comp ratio stamped into it. It is part of the engine block. Sometimes it is difficult to see with manifolds on. It will probably start with a 12 or 13. Most swapped motors came from Rover SD1s.
D Land Rover engine swop. Rover / Land Rover 1
BoyRacer Rover 3.5L (Buick 215 c.i.) Engine Swap Austin Healey 15
M T16 engine, ecu and two key fobs, or Rover 820 Rover / Land Rover 0
J Rover engine that started as Buick? Rover / Land Rover 9
S Rover 75.. NEW ENGINE!? WHY!!? Other British Cars 7
T Need Values for 2000 Rover 1.3 Twin Point Engine British Motor Corp 1
J For Sale Land Rover Discovery workshop manual 1995-1999 models, 4.0, 4.6 V8 & BMW diesel Other British Classifieds 0
J Land Rover research Rover / Land Rover 4
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
F For Sale Rover V8 blocks for sale Other British Classifieds 1
C For Sale Rover Mini Blue Star Tribute Other British Classifieds 0
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
CJRams For Sale 1996 Rover MGF 1.8i - $15,000 MG Classifieds 3
A For Sale Rover V8 heads, 10 bolt Other British Classifieds 0
A For Sale Supercharger setup complete for Rover V8 3.9/4.0/4.2 Other British Classifieds 3
A Land Rover V8 3.9L long block core for sale Rover / Land Rover 1
A MGB Donor Rover 3500 P6B for my MGB MG 5
albertemore Range Rover Classic Parts? Rover / Land Rover 5
G Rover P3 Brake Lining - Front Rover / Land Rover 2
hutten Wheel sizes for Rover Mini Mark VII British Motor Corp 1
PAUL161 Land Rover 73 Rover / Land Rover 0
Z MGB My 5.8 OHC Rover V8 build yes this is a P76 block from do under! MG 10
Steve Range Rover Evoque Convertible Rover / Land Rover 2
LarryK Land Rover Repair or just plain how to! Rover / Land Rover 1
catfood Land Rover Evoque Convertible Spotted 1
aeronca65t Landwind - fake Rover Rover / Land Rover 3
Steve Land Rover 90 vs. Dodge Ram Rover / Land Rover 1
Boink First Range Rover Rover / Land Rover 2
Nunyas Patrolicious - 1973 Land Rover Series III Other Cars 1
K Land Rover Defender - Mountain Rescue Team Rover / Land Rover 0
N Land rover and coffman cartridge starter Rover / Land Rover 0
HealeyRick A Visit to the Land Rover Factory Rover / Land Rover 0
B Rover V-8 main bearings Rover / Land Rover 5
G Rover 3.9 info?? Rover / Land Rover 1
JPSmit Land Rover Defender - and Home made special Spotted 1
aeronca65t Rover car carrier Rover / Land Rover 1
JPSmit Land Rover - hopefully good news. Spotted 9
aeronca65t Churchill's Land Rover For Sale Rover / Land Rover 1
aseriesspares LAND ROVER SERIES 3 Complete Hardware Sets 30% OFF Rover / Land Rover 0
Steve New Land Rover Defender Rover / Land Rover 9
58Custom Rover V8 in SoCal self-serve junkyard Rover / Land Rover 0
G Rover V8 interchange/swap question MG 9
rosalind Bye Old Rover...Hello new Rover Rover / Land Rover 2
aeronca65t Land Rover Forward Control Rover / Land Rover 0
T What car could use a Rover V8 Other Cars 3
Got_All_4 Wedge Rover 3.9 in a Tr7 Triumph 34
Steve Range Rover Evoque Rover / Land Rover 1
AngliaGT Rover 3500 Rover / Land Rover 1
M 2000 range rover????? Other British Cars 1
D 1935 Rover 10 wiring dia. and head lamp solonoid.. Rover / Land Rover 2
