Replacement frame
John Loftus
I'm looking for a reproduction frame for my 1958 bn4 100-6. Any vendor url or address who be greatly appreciated
I bought a Kilmartin frame through British Car Specialists, as well as many chassis parts for my Mark II, BN7. I was extremely impressed with how identical it is to the original, and how well the chassis parts fit together. I had the most trouble with the rear inner fenders, but Kilmartin does not make those, so they came from England. You can buy the frame parts individually, but it was well worth the additional $1900 to have the basic frame professionally welded together dimensionally correct. From there, it was then possible to assemble and weld together the rest of the chassis without requiring special fixtures (of course it required many assembly trials of the body components to get final alignment).
One down side of Kilmartin is that it may be a long wait. It was about 4 months from order until they built the frame, and then it took another 6 weeks to be shipped from Australia.
Good Luck,
Paul
Thanks for the post Alan. I looked at Weiler-Knight's website. I Didn't see any examples of "what they sell" (Frame/chassis parts), shown. Did you purchase a frame/chassis from them?
I have a BN4 with a Jule frame. It is currently in Wicker's body shop, Kendallville, IN (www.wickerizedhealey.com) and should have the paint ready to go on this week.
I am real happy with the Jule frame but have some details that could be improved if you are thnking of trying one. Incidently, you can spot one real easy at the next Healey car show. Look under the front cross member. The bottom is not even with the two main frame rails. This allows the brakes lines and wiring to be up and outof the way, not under the frame as original. One word of caution, it is not concours!
Wicker has done the body work on several Jule frame cars and is happy with the frame as it has less give and therefore less "body readjustment" after a few miles.
Jim
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Daelion:
<hr></blockquote>
You can see one I bought:
https://www.britishcarforum.com/PHPhotoalbum/displayimage.php?pid=761
I got it used from someone that found their original chassis was better than they thought. I believe that it originated with SC Parts.
www.scparts.co.uk
Is their website, though it is pretty unuseable- you'd do better to e-mail and ask them directly about such items.
I also know that the UK Healey Centre do replacement chassis too, though theirs appear to include "improvements":
https://www.ukhealey.co.uk/new_chassis.htm
is a page devoted to it.
Hope this helps.
[ 04-07-2004: Message edited by: JamesWilson ]
[ 04-07-2004: Message edited by: JamesWilson ]</p>
BobHaskell Mini Cooper rear subframe replacement British Motor Corp 3
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
F Spitfire Replacement Of Spitfire Convertible Top Frame Seal Triumph 6
W Replacement frame engine mounts for a 100-6 Austin Healey 4
T TR4/4A TR4/6 inner sill replacement - body on/off frame Triumph 1
J TR6 1975 TR6 Convertible Top Replacement. Triumph 1
wkilleffer MGB MGB windshield replacement near me MG 7
C TR4/4A Oil pan removal and replacement Triumph 27
C TR4/4A Install after jet gland replacement SU H6 in TR4 Triumph 9
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 25
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
WHT Rocker Arm Shaft Replacement Austin Healey 22
Celtic 77 MGB Seat webbing replacement. MG 1
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Celtic 77 MGB Seat Diaphragm replacement MG 0
Celtic 77 MGB 1977 seat webbing replacement. MG 1
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
K TR2/3/3A Wing mirror replacement again... Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
B T-Series Battery replacement mgtd MG 2
F TR4/4A Speedometer cable replacement access Triumph 0
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
T TR2/3/3A Replacement radiators Triumph 8
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
F TR4/4A Replacement air filter for SU HS6 Triumph 6
A MGB MGB 1974 windscreen centre rod replacement MG 5
B Poor quality BE replacement spring boxes Spridgets 0
AUSMHLY BJ8 Laygear Replacement Options Austin Healey 0
B TR6 Fuel tank replacement Triumph 0
S MGB clutch replacement MG 7
S Wiring Harness Replacement Spridgets 1
JPSmit Not something you see everyday - a warranty replacement Spridgets 1
M 1972 Midget Seat Belt Replacement Spridgets 4
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
T TR2/3/3A tr3 front carpet replacement Triumph 5
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
D Engine replacement. Rover / Land Rover 0
EWD TR6 Dash Pad Replacement Triumph 3
R TR6 fan shroud replacement Triumph 5
C Replacement wheels Rover / Land Rover 1
B TR4/4A Floor pan replacement Triumph 4
DrEntropy MGB Replacement starter MG 7
P TR6 1970 TR6 Passenger Sun Visor Replacement Triumph 1
M General MG Midget MK1 windshield replacement MG 2
M TR6 Replacement Steering Rack ? Triumph 7
