Replacement frame engine mounts for a 100-6
wolf
Talking with the owner of a 100-6 that I am considering he mentioned that the engine frame mounts had been cut off to put in a V8 before he got the car . Can these mounts be purchased ? or would the mounts have to be fabricated ?
Yep, pretty much all the metalwork is repro'd now. AH272R and AH272L are the part numbers from Kilmartin in Australia.
Also sold through various other sources.
https://www.atbrestorations.co.uk/ATBREST_catalogue_mainchassis.html
Look very closely around the engine and suspension mounts, degreaser it well if dirty as there will be cracks in the main chassis rail around the suspension and engine mounts. Mine is cracked and has bodgy repairs so I am replacing the entire chassis as the cost to renovate the original is the same as to replace it and the replacement ones have a few subtle improvements strengthwise.
Andy.
Wolf,
You may want to consider having Martin Jansen at Jule Enterprises https://www.jule-enterprises.com/index.html
Fabricate a new chassis and superstructure for you. for $8000 you have a good starting point.
rich...also starting a 100/6 restoration of my own.
57AustinHealey
The Kilmartin chassis frame will assure you are maintaining an excellent "as original" and exact duplicate except it has heavied up wall section and other features they've come up with to further strengthen the structure (not visible from the outside) for similar costs.
nother point with the Kilmartin chassis is you can get any body repair sections sent with the chassis for no extra freight cost as the freight is calculated on the size of the box not the weight. their website is rather lacking on details of what they produce but they make all the usual repair panels and sections.
I'm hoping to visit their factory in early December as I'm attending a motorsport event nearby.
Andy.
BobHaskell Mini Cooper rear subframe replacement British Motor Corp 3
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
F Spitfire Replacement Of Spitfire Convertible Top Frame Seal Triumph 6
T TR4/4A TR4/6 inner sill replacement - body on/off frame Triumph 1
John Loftus Replacement frame Austin Healey 8
J TR6 1975 TR6 Convertible Top Replacement. Triumph 1
wkilleffer MGB MGB windshield replacement near me MG 7
C TR4/4A Oil pan removal and replacement Triumph 27
C TR4/4A Install after jet gland replacement SU H6 in TR4 Triumph 9
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 25
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
WHT Rocker Arm Shaft Replacement Austin Healey 22
Celtic 77 MGB Seat webbing replacement. MG 1
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Celtic 77 MGB Seat Diaphragm replacement MG 0
Celtic 77 MGB 1977 seat webbing replacement. MG 1
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
K TR2/3/3A Wing mirror replacement again... Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
B T-Series Battery replacement mgtd MG 2
F TR4/4A Speedometer cable replacement access Triumph 0
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
T TR2/3/3A Replacement radiators Triumph 8
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
F TR4/4A Replacement air filter for SU HS6 Triumph 6
A MGB MGB 1974 windscreen centre rod replacement MG 5
B Poor quality BE replacement spring boxes Spridgets 0
AUSMHLY BJ8 Laygear Replacement Options Austin Healey 0
B TR6 Fuel tank replacement Triumph 0
S MGB clutch replacement MG 7
S Wiring Harness Replacement Spridgets 1
JPSmit Not something you see everyday - a warranty replacement Spridgets 1
M 1972 Midget Seat Belt Replacement Spridgets 4
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
T TR2/3/3A tr3 front carpet replacement Triumph 5
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
D Engine replacement. Rover / Land Rover 0
EWD TR6 Dash Pad Replacement Triumph 3
R TR6 fan shroud replacement Triumph 5
C Replacement wheels Rover / Land Rover 1
B TR4/4A Floor pan replacement Triumph 4
DrEntropy MGB Replacement starter MG 7
P TR6 1970 TR6 Passenger Sun Visor Replacement Triumph 1
M General MG Midget MK1 windshield replacement MG 2
M TR6 Replacement Steering Rack ? Triumph 7
