replacement body panels
KenASh
Hi folks,
Anyone have any recommendations for where to purchase Jag Etype 2+2 body sheet metal, panels etc? I'm gearing up to do the Mig & Plasma dance. Thanks for any replies.
Well I think Martin Robey here in the US may have the panels as well as XK's Unlimited In California.You can check them out and see.FWIW---Keoke
Try SNG Barratt's up in New Hampshire. They are probably the closest and the least expensive for shipping. Robey's will most likely have it in stock. Manner's is a great place for parts, but you will have to mortgage the E-Type to pay the shipping costs and in this case the Duty.
Webserve
Thanks to all who answered my plea for help! Ill scout them out.
Hello all,
Martin Robey is the major producer of replica panels for Jaguars, and most suppliers actually are selling Robey panels.
Alec
Ken,
I just received a new Jaguar catalogue from Moss Motors and one from Terry's Jaguar. I noticed that they (especially Terry's Jaguar) had almost everything for the XK bodies and almost nothing for the XJ's, or at least the panels I needed. Both suppliers have online Catalogues with prices, you may want to check them for comparison with the other vendors mentioned above. By the way, I haven't received their catalogue yet, but have seen the online version of XK's Unlimited at www.xksunlimited.com . They are very reasonable on their XJ prices and they specialize in XK restoration parts and services... definitely check them out before buying elsewhere... very helpful sales staff as well.
Regards,
Brian
Ken,
Just after I posted about XK's Unlimited, I checked their site... Here is the link dedicated to the XKE 2+2, but check the entire XKE catalogue, there is so much more. Hope this helps. Call their number to request a free paper copy of the Jaguar Master Catalogue, there may also be a link on the homepage for the request....
XKE 2+2 Body Panels Link:
https://www.xksunlimited.com/xks/merchant.ihtml?id=439&step=2
Brian
Brian,
Thanks for the links and leads.
Ken,
No problem, let us all know where you find the best deal. If you run across a rear underbody supplier for the Series III XJ's, please let me know. Still having trouble offering the rusty thing as a take-a-part car.. got too attached to be reasonable. Good luck on your search.
Brian /ubbthreads/images/graemlins/cheers.gif
H GT6 Replacement body panels Triumph 4
C TR2/3/3A TR2-3 Replacement Body Panels Triumph 1
Rut Bugeye body panels and replacement Spridgets 4
T TR2/3/3A TR3 replacement body panels Triumph 14
C Expereince with Moss motors replacement body panels MG 13
J TR2/3/3A Body Restoration - Inner Sill Replacement Triumph 38
Editor_Reid Body Number Plate Replacement Austin Healey 13
T TR4/4A TR4/6 inner sill replacement - body on/off frame Triumph 1
angelfj1 Help Need replacement body ID tag Triumph 8
C TR4/4A Install after jet gland replacement SU H6 in TR4 Triumph 0
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 24
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
scottkilpatrick TR4/4A Difficulty Level Opinion - Differential Gasket Replacement 62 TR4 Triumph 10
WHT Rocker Arm Shaft Replacement Austin Healey 21
Celtic 77 MGB Seat webbing replacement. MG 1
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Celtic 77 MGB Seat Diaphragm replacement MG 0
Celtic 77 MGB 1977 seat webbing replacement. MG 1
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
K TR2/3/3A Wing mirror replacement again... Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
B T-Series Battery replacement mgtd MG 2
F TR4/4A Speedometer cable replacement access Triumph 0
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
T TR2/3/3A Replacement radiators Triumph 8
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
F TR4/4A Replacement air filter for SU HS6 Triumph 6
BobHaskell Mini Cooper rear subframe replacement British Motor Corp 3
A MGB MGB 1974 windscreen centre rod replacement MG 5
B Poor quality BE replacement spring boxes Spridgets 0
AUSMHLY BJ8 Laygear Replacement Options Austin Healey 0
B TR6 Fuel tank replacement Triumph 0
S MGB clutch replacement MG 7
S Wiring Harness Replacement Spridgets 1
JPSmit Not something you see everyday - a warranty replacement Spridgets 1
M 1972 Midget Seat Belt Replacement Spridgets 4
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
T TR2/3/3A tr3 front carpet replacement Triumph 5
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
D Engine replacement. Rover / Land Rover 0
EWD TR6 Dash Pad Replacement Triumph 3
R TR6 fan shroud replacement Triumph 5
C Replacement wheels Rover / Land Rover 1
B TR4/4A Floor pan replacement Triumph 4
DrEntropy MGB Replacement starter MG 7
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
