Recomendations for Distributor rebuilder
Brosky
I would like to have my distributor rebuilt over the winter months. I'm looking for a complete overhaul. I once saw a site that I thought was in NY, that looked pretty good, but now I can't find it. Any suggestions?
Thanks,
Paul,
If you simply want a rebuilt Lucas distributor try Rockauto and select Cardone part#31-409. ($168+$50core) Use your old distributor as a core or hang onto it as backup. I've attached photo of mine.
That's the guy that I read about awhile back. Does he have a website or is there and article that you know of relating to him?
I have only the second hand knowledge from members of other sites. Ill see if I can get there info.
Here is a blurb from him
Distributor and/or ignition problems are often thought to be carburetor related. I can help diagnose you TR. Just email me. I can also rebuild your distributor.
Complete TR250/6 Distributor Restoration and Repair – all units disassembled and meticulously cleaned. Housings glass bead blasted and polished. Oilight bushing(s) individually turned and replaced. Shaft and action plate assembly aligned and balanced. Springs, seals, screws and terminal lead replaced. Vacuum unit(s) tested and repaired. All units dynamically tested on a Sun Distributor Tester/Lab Scope and brought back to OEM specifications. Complete performance documentation and specifications provided with each distributor. Performance curve modifications, complete ignition diagnostics and powder coating available. References and photo examples upon request. Contact Bob Sarama at lucasdistributors@yahoo.com
B TR4/4A Roll Bar Recomendations Triumph 7
I Engine leveler recomendations? Spridgets 5
EinsteinsDad need Wiring Harness recomendations Restoration & Tools 7
B Castrol Oil Recomendations for Classic Cars Triumph 3
G Brake fluid recomendations - 1950's JAG XK140 Jaguar 19
A New carpet comparisons and recomendations?? Triumph 11
Adam58 Recomendations or warnings on transport services? MG 19
A Rear camber findings and adjustment recomendations Triumph 4
P Starter recomendations Triumph 7
A TR6 Clutch Master Cylinder-tr6---recomendations?? Triumph 3
D Spitfire Spitfire tire recomendations? Triumph 2
MattP Recomendations and warnings MG 5
jtb55 Brake shoe suppliers and compound recomendations Austin Healey 1
G Recomendations for Machine shop In Boston area Other British Cars 1
C Paint Shop Recomendations MG 1
B TR4/4A Some Help with Setting Distributor Triumph 47
C MGB New plug wires and distributor cap MG 10
M Accuspark distributor Spridgets 2
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
K TR2/3/3A Dr Distributor shipping? Triumph 4
E TR6 Rebuilding Distributor Triumph 2
K TR2/3/3A Distributor internal wires? Triumph 5
PAUL161 T-Series My 55 TF Xpeg Distributor MG 2
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
JPSmit Distributor question Spridgets 0
B MGB 42d4/45d4 distributor MG 0
S TR2/3/3A Installing the distributor pedestal. Triumph 3
A TR6 TR6 Distributor cap issue Triumph 4
C MGA Setting a 123 distributor MG 0
K TR2/3/3A A couple of small distributor tech questions..... Triumph 10
vette Distributor Advance Austin Healey 14
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
AngliaGT MGB-GT Extremely Dumb Question - Distributor Hose - SOLVED! MG 3
1275GT Wanted 23D4 distributor #40819 Other British Classifieds 0
M TR2/3/3A 25D4 CSI Optimized Distributor Triumph 4
T TR4/4A Why are distributor base plates different, is this a problem? Triumph 7
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
steveg 100-4 Distributor Internal Ground Wire Austin Healey 6
WJKB-TR6 TR6 '73 Distributor Cap Brush Triumph 5
R Distributor: Reassembling BJ8 Engine Austin Healey 5
Lin Jaguar Distributor Cap for Healey Austin Healey 8
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A Aftermarket Distributor Points and Terminal Bush leads? Triumph 1
S For Sale TR3 front nose,trunk & petronix distributor Triumph Classifieds 0
P DM6A Distributor Question Austin Healey 9
