Rebuild is finished!
Simon TR4a
After an off-track "incident" 3 years ago I have finally finished rebuilding my damaged TR4a.
This involved purchasing a rust-free donor car rather than trying to straighten my damaged chassis, as this also gave me a better inner tub to work with, and included pieces like a grille and bumpers which I needed anyway. The bottom line was I ended up with a better car for a bit more money.
It was a complete rebuild from the bare frame up, using as much of my original car as I could, and another car was rebuilt on the basis of my old inner tub, so there is not one less TR4a in the world, in fact there is one more!
I used a professional paint shop to sand blast and paint the body and all bolt-on panels, but did all the assembly myself, bought new trim as needed, new radiator and fan (it was a front end hit), and new soft top and carpet set.
Although I am a bit nervous, I am really looking forward to getting the car back, even though the Spitfire we bought to substitute has been a great little car in the meantime, and I will regret selling it.
Thanks to all who offered advice and encouragement along the way!
Simon.
Geo Hahn
Good to hear its back.. I recall when the incident took it off the road.
We have local fellow going thru a nearly identical process (using a donor car for half a frame and much sheet metal) to save his TR4 that was rear-ended by a Ford Expedition (or Excursion, whichever is the big one). He had 700K on that TR4 so, like you, he was determined that it be saved.
Simon TR4a
Simon TR4a
I have tried to create an album at photobucket (not good with computers). I think you can search by SimonR_photo and the subtitle TR4a rebuild.
Thanks, Simon.
Brosky Heater case rebuild project finished Triumph 15
C Wanted Spitfire 1500 diff rebuild Triumph Classifieds 0
E Spitfire 74 Spit Rebuild Triumph 4
Carlbanan56 MGB MGB rear break rebuild MG 6
6 Master Cylinder Rebuild Spridgets 6
wangdango Carb Rebuild Necessity Austin Healey 3
drooartz MGB Front suspension rebuild is next MG 57
KVH General Tech Rebuild Report Triumph 6
KVH General Tech Initial Start Up After Rebuild Triumph 23
KVH General Tech More Engine Rebuild Questions Triumph 15
G MGB '71 MGB Front End Rebuild MG 2
drooartz MGB A nice milestone since the rebuild MG 3
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
I Bugeye valve rebuild suggestions Spridgets 8
D MGB 25D dizzy rebuild MG 29
R Rib Case rebuild... Spridgets 5
K TR2/3/3A Further to brake caliper rebuild.... Triumph 2
woolfman C39 vs C40 Dynamo rebuild/parts Spridgets 0
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
C TR2/3/3A TR3A clutch/brake cylinder rebuild Triumph 4
B TR2/3/3A TR3a steering box rebuild Triumph 19
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
TAS525 TR2/3/3A Steering Box Rebuild? Triumph 19
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
mrv8q TR2/3/3A Brake master cylinder: rebuild or replace? Triumph 9
RJS General TR TR4A Seat Rebuild Triumph 12
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
J Transmission and Overdrive Rebuild Austin Healey 6
J TR6 TR6 Differential Rebuild question Triumph 6
Tr3aguy TR2/3/3A Rear Axle Rebuild Triumph 3
pkmh BJ8: Upper Trunnion Rebuild [Of Continuum] Austin Healey 9
jfarris TR2/3/3A Happy with my Paltech Carb rebuild Triumph 8
6 Smith heater rebuild Austin Healey 8
J Front Suspension Rebuild Austin Healey 16
EWD TR6 74 TR6 - Carbon canister rebuild Triumph 2
R TR6 Gearbox rebuild issues Triumph 8
J Engine rebuild Austin Healey 4
S TR4/4A TR3/4/4a Transmission rebuild question Triumph 7
R TR2/3/3A 1961 TR3A Master Cylinder[s] Rebuild Kits Triumph 4
B BJ7 back end rebuild Austin Healey 1
M TR6 Clutch Master Rebuild: That Crazy Wavy Washer Triumph 1
classicmechanic Amazon engine rebuild pics Other Cars 6
W XKs Motorsport gearbox rebuild fiasco Jaguar 5
