TR6 Rear View Mirrors for UK TR6
G
Hey guys,
I have been trying desperately to find the outside rearview mirrors that only came on early TR6's made for the UK. Moss-UK has a beautiful color photo in their online catalog and the are described as "Early Style Long Arm Mirror Assemblies". With glee I ordered them and promptly received some round mirrors that looked like they belong on a TR3. Rather than hastle with returning them, I sold those to an MG guy at a car show. And they don't respond to email. Rimmer has the same listing but supercedes the catalog number with a listing for just a different item. Anyone have a set they want to sell, in new condition, or know where I can buy them? These are large parabolic shaped mirrors that look like they came off of 60's American hardtop. The bullet mirrors on the car now are a pain to adjust, and the right one is for show only, unless you are the passenger. And please, don't anyone mention Miata.
Bill
G
Well, I finally called London and talked to a salesman (love that accent) at Moss Motors UK to try and track down a pair of TR6-UK rearview mirrors. I called on Monday and on Wednesday received a beautiful set of stainless mirrors that give outstanding rear vision. Well made and relatively cheap. I saw some on photos of right-hand-drive TR6. These things are really large, give excellent vision and fit the style of the TR6 extremely well. In fact, they were made for the 6. Never understood why the US versions never had them. The cone-style mirrors we all have look like something that came out of the JCWhitney catalog. Pays to be persistant to find what you want.
Bill
mike crane
Member
Dr Bill Do your new mirrors use the same mounting bracket as the ones they replace? Also do you have a part number? The bullet mirror on my 6 is virtually worthless. Thanks Mike C
[/LIST]
G
Mike,
Look up <moss-europe.co.uk> and wade your way up to the Triumph exterior accessories pages and the mirrors with the #6 by it is the one. The numbers on the boxes (made by TEX, the same people that make your wiper blades, etc.) YKC2960 and YKC2959. You are right, the bullet mirrors are useless...
Bill
G
Oh, and they don't use the same hole but the base is larger than the bullet base, one hole can be used and a new one drilled. Presents no problem.
Bill
G
Mike,
I just installed the first mirror on my 6, the right one. Had to modify the setup slightly. Redrilled the front hole in the door about 1/2 inch forward of the existing hole, using the plastic base for the mirror as a template. Backed up their plastic base with a piece of 1/8" rubber sheeting cut to fit. Used #10-24 stainless bolts to hold it to the door firmly. The mirror came with some sort of friction/expansion screw - not acceptable. These are there to stay. LOOK GREAT - EXCELLENT VIEW....
Bill
Bugeye58
Bill, make sure to take a small brush and paint the edges of the old holes to protect them as much as possible. I've seen cars where the mirrors have been moved in the same manner, and the only way you could tell was by the streak of rust coming from under the base gasket!
Jeff
B BT-7 Rear View Mirrors Austin Healey 5
Johnny AH convertible rear view mirrors Austin Healey 9
H auxillary rear view mirrors Austin Healey 4
R Body Rear View Mirrors Austin Healey 3
P Rear View Mirrors Sunbeam (Rootes) 3
petnatcar Rear View Mirror Relocation Austin Healey 0
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
Editor_Reid Rear-View Mirror Search Austin Healey 4
AngliaGT Midget Rear View Mirror - What Will Work? Spridgets 1
D Rear view mirror shaft Austin Healey 6
C TR4/4A Rear view Mirror Triumph 15
B Rear view mirror location for BJ8 Austin Healey 14
HealeyRick BJ-7/8 Rear View Mirror Day/Night Mirror Austin Healey 10
RAC68 Lopsided Rear View Austin Healey 13
O rear view mirror screws Austin Healey 5
arizonamike TR5/TR250 TR250 Inside Rear View Mirror Mount. Triumph 2
sparkydave Rear view mirror set screw Spridgets 0
N Dimming rear view mirror?? Spridgets 15
B rear view mirror 56 bn2 Austin Healey 9
D Rear-view mirror Spridgets 7
J TR2/3/3A TR3A rear view mirror placement Triumph 13
chrpark rear view mirror - another 'holes' question Spridgets 6
msoylemez Wanted: Original Bugeye Rear View Mirror Spridgets 12
71TR6 Loose rear view mirror Triumph 4
Jim_Gruber Replacement Rear View Mirror '70-79 style Spridgets 14
jmwuva05 Rear view mirror Spridgets 2
drooartz De-bondoing rear view mirror holes Spridgets 20
Team_Sprite Rear view mirror question Spridgets 41
jlaird Seems to me - Rear view mirors Spridgets 29
MadRiver Anyone replace the glass in a rear view mirror? Triumph 1
S Rear view mirror Austin Healey 23
T Rear View Mirror Repair on a 1976 TR Triumph 2
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
S Leaking HD6 Rear Carb Austin Healey 10
