TR6 Rear Oil Seal?
JFS
Bronze
Upon draining the engine oil on a TR6, a spring measuring about 9" long came out the sump drain hole. The spring is tapered on one end and fits into the other end. Is it possible for the spring in the rear oil seal to break loose and drop into the oil pan? The engine was recently rebuilt.
If it's about 1/8 inch across, that is the only thing in there it could be. Possible it was done on installation. Not centered when pushed over the crank end.
D MG Midget 1275 rear oil seal. Spridgets 0
A Rear Axle Oil Seal Austin Healey 4
J Rear Oil Seal Kit - Spring Austin Healey 9
drooartz Rear wheel hub oil seal Spridgets 6
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
AUSMHLY BJ8 rear axle oil seal Austin Healey 6
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
B TR6 Rear Oil Seal Housing Triumph 2
B TR6 1971 clutch and rear oil seal Triumph 2
S Rear crank seal oil leak BN2 Austin Healey 20
B Rear Wheel Bearing Oil Seal Spridgets 7
TulsaFred Rear Hub bearing and oil seal tips Spridgets 0
F More oil leaking...rear seal? Triumph 3
A Rear Axle Oil Seal Spridgets 2
P Rear axle oil seal Austin Healey 4
T Rear axle oil seal Austin Healey 4
T rear axle oil seal replacemeent Spridgets 15
rjc157 moss rear crank oil seal Austin Healey 4
TR3TR6 TR2/3/3A TR3 rear oil seal Triumph 2
vette Crankshaft Rear Oil Seal Austin Healey 11
mgnewbie Speedi-sleeve for the gearbox rear oil seal MG 7
PAUL161 72 Overdrive rear oil seal question. MG 0
MGTF1250Dave TR2/3/3A TR3A Rear Axle Pinion Oil Seal Replacement Triumph 8
B Help to replace 3000 leaking rear axle oil seal ? Austin Healey 25
drooartz Rear hub oil seal removal Spridgets 4
J Oil Leak Thru Rear Seal? Spridgets 10
A Rear Main Oil Seal Conversion - Bearing Cap debris Austin Healey 5
2wrench Rear oil seal...silicone or not? Triumph 30
S TR2/3/3A TR3 rear oil seal conversion kit Triumph 3
JPSmit Very Quick Question - rear oil seal Spridgets 2
W T-Series MGTD rear oil seal leak MG 7
tahoe healey rear oil seal vs. gasket Austin Healey 2
AUSMHLY Rear Axle leaking from oil seal dust cover Austin Healey 58
G TR5/TR250 TR 250/early 6 rear pinion oil seal Triumph 0
Woodie rear oil seal leaking Spridgets 11
cutlass29 Spitfire spitfire mk3 rear engine oil seal Triumph 1
zimmy rear oil seal Spridgets 3
A Clutch Replacement + Rear Crank Oil Seal Replace? Austin Healey 8
A Engine Rear Oil Seal Austin Healey 12
S TR2/3/3A Tr3 rear axel oil seal and shim Triumph 0
S TR2/3/3A Tr3 original rear oil seal Triumph 9
E rear oil seal Spridgets 1
bluemiata90 TR2/3/3A TR3 engine rear oil seal Triumph 23
C rear main oil seal Austin Healey 4
G TR4/4A Rear Oil Galley Plug Sealing Triumph 21
J TR4/4A Oil leak from rear of motor. Triumph 28
warwick-steve Oil for rear axle? Austin Healey 3
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
B How often should you change the rear rear axle oil Austin Healey 9
